Thread: Intercooler core install?
Results 1 to 11 of 11
  1. #1 Intercooler core install?
    Minnesota
    After cutting my own gaskets out of a material PRJ suggested, I still had leaks. I then spread RTV all over the gaskets on both sides and installed them. This made for a tight seal but was way too hard to take off and broke my core upon removal.
    Instead of buying some more of the expensive material again I went to O'Reillys and bought some material I found there for $5 a roll. I then cut some gaskets out of that:
    It's 1/16 of a inch and made of rubber and fiber (Fel-Pro #3157). It should work out well for this application and it way more flexible and should seal better than Garlock gaskets.
    The question I have now is not to use RTV or not, but how much to use?
    I found these pictures on what ZZP says for the install of their cores with Garlocks. I am wondering if anyone has put the RTV on like this with success.
  2. #2 Re: Intercooler core install?
    Omaha, NE
    Yes, that is the proper way to RTV.
    I'm kind of confused about how you had a hard time getting the RTV to separate...
  3. #3 Re: Intercooler core install?
    Minnesota
    I spread it all over the gaskets on both sides. I didn't only do a small bead like shown in the picture above.
  4. #4 Re: Intercooler core install?
    I use that same Fel Pro stuff and Permatex 26B like you see in the pictures you posted. it can still be tough to seperate, but it will seperate.
    I found carb cleaner broke most of the bonds.
  6. #6 Re: Intercooler core install?
    Omaha, NE
    Carb cleaner or brake cleaner are great to break RTV. If those don't do the trick, use a poking tool to break the seal then run the smallest screwdriver you can find across until you can break it by hand. Don't apply pressure at an angle with a tool, phenolic and aluminum don't like that.
    Along with the thin lines above, you can run a ring around the outside for added insurance against leaks. Thats how I did it (without a gasket) and never ran into a problem after that.
  7. #7 Re: Intercooler core install?
    Apr 2009
    Fort Worth TX
    A thin narrow putty knife works good also.
    Get it started and use the palm of your hand to tap it in.
    It usually destroys the gasket though.
    Don't ever pry with a screw driver; you'll ding, dent and bend the hell out of the parts.
  8. #8 Re: Intercooler core install?
    You guys don't quite understand..lol.
    I use a prybar to pop the core loose.
  9. #9 Re: Intercooler core install?
    Minnesota
    That's what I had to use when I was taking the core off this last time and I broke it. I think I went a little overboard on the RTV lol
    I will be doing the bead and instead of spreading it all over like I am making a peanut butter and jelly.
  10. #10 Re: Intercooler core install?
    Minnesota
    This is the same thing im doing here are the gaskets I cut. I feel like I am missing some holes, but these were the only ones that were on the core. But I think the lim has a few different ones that dont line up?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  11. #11 Re: Intercooler core install?
    Minnesota
    Mine is all sealed up. I am going to give it 24 hours before I start it up. Cross your fingers.
    New axles tomorrow with the modded sway bar end links and I should be good to go.
  1. intercooler install
    By jrock in forum General Tech Discussion
    Last Post: 06-07-2012, 05:49 AM
  2. intercooler install
    By JROCK1987 in forum General Tech Discussion
    Last Post: 02-23-2012, 06:21 AM
  3. ZZP Stage 2 Intercooler Install help
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 07:10 AM
  4. intercooler gasket information needed
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2008, 08:15 PM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
