Thread: Outside temp
Results 1 to 10 of 10
  1. #1 Outside temp
    Jun 2012
    Kansas
    How does the outside temp gauge work? Mine does not seem to be reading as its supposed to any help would be appriciated
    Also if I was to clean the drain on the ac how do I do Otis there something under the dash or is it in the engine compartment
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Same, mine will say like EXT 31 even though sometimes it will be correct and say like EXT 78 or whatever the temp is.
  3. #3 Re: Outside temp
    open the hood under the latch in the grill area, you will see a sensor, thats your out side temp sensor. i think someone said its a dealer only item. not 100% sure tho.
    Mar 2012
    Minneapolis MN
    So it could just be shot then?
  5. #5 Re: Outside temp
    Jan 2012
    Philadelphia
    wish i had one of them lol
  6. #6 Re: Outside temp
    no you dont, mine said 100 outside yesterday and today lol
  7. #7 Re: Outside temp
    Jan 2012
    Philadelphia
    well it told you the truth even though you didnt wanna here it lol
    i hope you weren't working out side like i was today
  8. #8 Re: Outside temp
    im laid off, so its nice in the a/c at home. but i did go out to wash the car, and it was brutal.
  9. #9 Re: Outside temp
    Correct.
    Dealer only item. Cost is 12-15 bucks.
    Replace it and be on your way. Also if you dont replace it and you try and use the AUTO air feature and or the AC, its likely not the work because if the sensor says its too cold outside it wont turn anything on.
  10. #10 Re: Outside temp
    Jan 2012
    Philadelphia
    i work 9-5 during the week and today i was outside pulling an engine and Trans on an old Ford (390 BB), today was brutal. came home sat in the air for a little bit them got up went outside and washed the GP and did a little bit of body work on the 52 p/u then came back inside and chilled out hopefully tomorrow wont be so bad.
  1. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  2. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  3. trans temp
    By stishdr in forum General Tech Discussion
    Last Post: 07-31-2011, 09:31 AM
  4. Is my temp okay?
    By tracker1925 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 07:52 AM
  5. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
