Thread: No power!
Results 1 to 9 of 9
  1. #1 No power!
    Jun 2012
    San Antonio
    Proud owner of an 07 Grand Prix.
    Two days ago I swapped the battery on my car becasue it was giving me issues starting in the mornings. Since it was late Sunday and my nearest Auto Zone was closed I decided to swap the battery from another car that is just sitting in my garage. I noticed the battery was larger and had more crancking than the original so I kinda rigged it by finding a new ground for it. Car started up and drove around with no problems. Well today the car suddenly died on me at a light without any warning. No power whatsoever. I messed with the battery cables which were a bit lose and coroded and heard power come on. The car started like nothing for a few seconds and died again without any power. Someone offered jumpercables but nothing. My question is, can this be my alternator issue? Doesn't the problem start with interior lights or headlights fading first? It's got to be electrical in my mind. I'm about to clean and retighten the posts. I will also check to see if the new ground is adequate or if any lose cables got crimped. If anyone has had this happen before please help.
    Sorry for the long post.
    Thanks in advance!!
  2. #2 Re: No power!
    Get some non-corroded parts...first off.
  3. #3 Re: No power!
    Jun 2012
    San Antonio
    44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 44444444444444444444444444444444444444444444444444 4444444444444444
  4. #4 Re: No power!
    Quote Originally Posted by elejes View Post
    Cool story...can you tell it in English?
  5. #5 Re: No power!
    Jun 2012
    San Antonio
    Will do! Corrosion causes your car to come to a sudden stop with no power
  6. #6 Re: No power!
    yes, that and loose connections. or old crapped out cables.
  7. #7 Re: No power!
    Jun 2012
    San Antonio
    Thanks for the responses. In English!
  8. #8 Re: No power!
    Jun 2012
    San Antonio
    Cleaned out the posts, which were not corroded as bad as I thought. It turned out to be the ground wiring which I moved back to it's original place. Car got power and started, but it looks like I will be needing a new battery. Thank for all the help, especially the guy with his panties in a bunch...In English.
  9. #9 Re: No power!
    the neg cable from the battery needs to be bolted to the engine. sand the new spot up clean first, and the cable if its old. and bolt it down.
    clean all connections.
  1. 97 GTP has hardly any power.
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2011, 03:20 PM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. no power
    By killerkrayon in forum General Tech Discussion
    Last Post: 04-28-2011, 06:13 PM
  4. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  5. How much power do i have
    By gp3800t in forum General Tech Discussion
    Last Post: 03-18-2009, 02:39 PM
