Thread: Possible Bad CV Joint??
Results 1 to 7 of 7
  1. #1 Possible Bad CV Joint??
    Mar 2012
    Nebraska
    I have a 1999 GT. I have noticed lately that at highway speed there is a slight vibration and also when I apply the brakes anywhere above 50MPH. Also, when the car is sitting still and I turn the steering wheel there is a loud pop that comes from just inside the driver side front wheel. Any thoughts on what this might be?
    -'99 Grand Prix GT-
  2. #2 Re: Possible Bad CV Joint??
    Donating User Odi's Avatar
    Chicago South Suburbs
    if it also vibrates on acceleration then its the half axle. but what youre describing is most likely a bad hub.
  3. #3 Re: Possible Bad CV Joint??
    Agreed, sounds like bad wheel bearing or maybe brakes. The pop is typically a strut mount
  4. #4 Re: Possible Bad CV Joint??
    Mar 2012
    Nebraska
    Whats a good way of troubleshooting further to see if it is the hub? Jack it up and see if there is any play when you try moving the tire?
    -'99 Grand Prix GT-
  5. #5 Re: Possible Bad CV Joint??
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Id like to know this too ^^^^^^^^^
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  6. #6 Re: Possible Bad CV Joint??
    GTP Level Member
    springfield IL
    Sounds more like a bearing/hub.... Does it make the sound when ur in reverse and got the wheel turned all the way?
  7. #7 Re: Possible Bad CV Joint??
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    When my front left bearing was going out, i heard a a weird grinding type noise when turning left. Especially when on 1 of those sharp turns thats consistent. Also, do check the bearing by jacking the car up and shaking the tire to see if theres play, spin the tire also. Or take the tire off an spin the hub to see if you can get a closer sound.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  1. CV Joint
    By selym17 in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 04:07 PM
  2. CV Joint Maybe?
    By BrewMaster in forum General Tech Discussion
    Last Post: 01-14-2012, 08:37 PM
  3. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  4. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  5. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
