Thread: Possible Bad CV Joint??
Results 1 to 7 of 7
  1. #1 Re: Possible Bad CV Joint??
    GTP Level Member
    springfield IL
    Sounds more like a bearing/hub.... Does it make the sound when ur in reverse and got the wheel turned all the way?
  2. #2 Re: Possible Bad CV Joint??
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    When my front left bearing was going out, i heard a a weird grinding type noise when turning left. Especially when on 1 of those sharp turns thats consistent. Also, do check the bearing by jacking the car up and shaking the tire to see if theres play, spin the tire also. Or take the tire off an spin the hub to see if you can get a closer sound.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  1. CV Joint
    By selym17 in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 04:07 PM
  2. CV Joint Maybe?
    By BrewMaster in forum General Tech Discussion
    Last Post: 01-14-2012, 08:37 PM
  3. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  4. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  5. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
