Thread: On to my next problem, rough idle!!!
Results 1 to 6 of 6
  1. #1 On to my next problem, rough idle!!!
    the desert
    So I finally got my car to run and no more coolant mixing with oil because of the lim gasket replacement. Now on to my next problem. My cars idle is horrible. The rpm gauge jumps up and down and the exhaust sounds like its choking and using all its energy to run. I had this problem before an egr delete and before I replaced the lim gaskets. There are no check engine codes either. I also replaced the vacuum lines and the problem still exists. Any ideas? Thanks
    99 grand prix gtp
  2. #2 Re: On to my next problem, rough idle!!!
    Mar 2012
    NC
    Idle air control valve?
  3. #3 Re: On to my next problem, rough idle!!!
    the desert
    would that throw a code?
  4. #4 Re: On to my next problem, rough idle!!!
    Mar 2012
    NC
    not until it happens on 2 or three consecutive drive cycles
  5. #5 Re: On to my next problem, rough idle!!!
    the desert
    this happens every time i drive and has been happening for awhile
  6. #6 Re: On to my next problem, rough idle!!!
    Mar 2012
    NC
    Well, a drive cycle doesn't just mean turn the car on and drive around...it's a long drawn out thing. Like the car needs to start up below a specific temp, wait a certain amount of time at idle, drive for a certain amount of time at a given speed, stop and idle some more. It's kinda a pain in the nutsack.
  1. rough idle
    By mcsddd in forum General Tech Discussion
    Last Post: 01-15-2012, 03:58 PM
  2. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  3. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  4. GTP Rough Idle
    By jaredhagen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 01:32 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
