Thread: Car wont start!!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 68
  1. #1 Car wont start!!
    the desert
    so i turned my car on it started sounded like it was choking then turned off by itself. Now when I try to turn the car on it wont start and the battery light lit on the dashboard. What could be wrong? Thanks
  2. #2 Re: Car wont start!!
    Ohio
    year make model
  3. #3 Re: Car wont start!!
    the desert
    1999 pontiac grand prix gtp
  4. #4 Re: Car wont start!!
    Charles City, IA
    does it turn over?
    SMGPFC Two Nipple General
  5. #5 Re: Car wont start!!
    the desert
    yes
  6. #6 Re: Car wont start!!
    Mar 2012
    NC
    If you push the schrader valve in on the fuel rail after cranking, does fuel spray out or just dribble?
  7. #7 Re: Car wont start!!
    Charles City, IA
    Do you have spark?
  8. #8 Re: Car wont start!!
    Ohio
    im gonna throw out the resistor for this one to be tried first.
    find the fuel pump relay in the under hood fuse block, bend tab 85 out so it cant go back in. this should keep the fuel pump in high speed mode tricking the resistor. if this doesnt work then you have another problem. good luck
  9. #9 Re: Car wont start!!
    the desert
    i just remembered that i replaced the intake manifold gaskets but i didnt spray starter fluid on the manifold. could that be a reason?
  10. #10 Re: Car wont start!!
    Charles City, IA
    So was it running, or did you take it apart and now it wont start?
  11. #11 Re: Car wont start!!
    the desert
    i did the intake gaskets then it was running. Then i messed up where my thermostat housing goes. So I had to replace the LIM. So basically had to do the job again. But this time i forgot to spray starting fluid.
  12. #12 Re: Car wont start!!
    Charles City, IA
    You spray after its running to check for leaks. Make sure you have everything plugged in. Did you have the coil pack bracket off again?
  13. #13 Re: Car wont start!!
    the desert
    No I didnt take the coil pack off.
  14. #14 Re: Car wont start!!
    Charles City, IA
    ok, so do you have spark and fuel pressure? and injector pulse?
  15. #15 Re: Car wont start!!
    Charles City, IA
    And the plug wires on right.
  16. #16 Re: Car wont start!!
    the desert
    how do I know if I have spark and fuel pressure and injector pulse?
  17. #17 Re: Car wont start!!
    Mar 2012
    NC
    Spark is easy...take off spark plug wire from spark plug, hold the end in your hand, have someone crank the car...if you get shocked, you have spark.
  18. #18 Re: Car wont start!!
    the desert
    good one
  19. #19 Re: Car wont start!!
    Mar 2012
    NC
    Seriously, it works. It's only 60kV...it'll sting like hell but you certainly need to know. The fuel check is to push in the little schrader valve like I said in my first post.
  20. #20 Re: Car wont start!!
    OMG Jason. I'm surprised checking for fuel pressure doesn't involve drinking gas with a check like that for spark.
    Personally, I like to spend the $3 on an inline spark tester. It's a simple flashing light that tells you if spark is present. \
    A fuel pressure gauge will tell you about the pressure
    Injector pulse..that can be tested with a 194 light bulb.
  1. Help help gtp wont start
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 10:12 PM
  2. new used pcm car wont start
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2011, 09:43 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
