Thread: Car idle jump and water from exhaust pipe
Results 1 to 19 of 19
  1. #1 Car idle jump and water from exhaust pipe
    the desert
    Can someone please help me. My car has water dripping from the exhaust pipe. The rpms bounce at idle and make my car jump and shake. It sounds like my exhaust is all clogged up or something. Thanks
  2. #2 Re: Car idle jump and water from exhaust pipe
    Water from the exhaust is normal until the engine has ran for a while and burned all the condensation out of the pipes. Do you have any codes?
  3. #3 Re: Car idle jump and water from exhaust pipe
    the desert
    i just have an egr code because the egr was deleted. But the car started jumping before the egr was taken out
  4. #4 Re: Car idle jump and water from exhaust pipe
    Have you ever tuned it up? Have you had it scanned to see if there was another code?
  5. #5 Re: Car idle jump and water from exhaust pipe
    the desert
    I scanned it today and i got a p0403 and p0405. one is the egr and the other is the egr sensor+ Reply to Thread
  6. #6 Re: Car idle jump and water from exhaust pipe
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I'm dealing with the same thing right now. Unplug your MAF sensor and see if there's a difference.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  7. #7 Re: Car idle jump and water from exhaust pipe
    the desert
    i took the sensor out and it still does the same thing. There's also some white smoke coming out the exhaust.
  8. #8 Re: Car idle jump and water from exhaust pipe
    white is coolant.
    Sounds like you got more than 1 problem.
  9. #9 Re: Car idle jump and water from exhaust pipe
    the desert
    it used to be a lot of white smoke but then i changed the lim gasket so now theres barely any. The little bit i saw might just have been leftover or something.
  10. #10 Re: Car idle jump and water from exhaust pipe
    the desert
    99 grand prix gtp
  11. #11 Re: Car idle jump and water from exhaust pipe
    what is your car, make engine year?
  12. #12 Re: Car idle jump and water from exhaust pipe
    the desert
    yes im sure. The car was jumping before the lim job.
  13. #13 Re: Car idle jump and water from exhaust pipe
    did you just finish the lim job? if so are you sure the plug wires are on right.
  14. #14 Re: Car idle jump and water from exhaust pipe
    check engine light on?
  15. #15 Re: Car idle jump and water from exhaust pipe
    the desert
    yea its on but just a p0403 and p0405 because of an egr delete. The car was jumping before the egr delete too
  16. #16 Re: Car idle jump and water from exhaust pipe
    St. Louis
    You took the MAF out of the TB, or just disconnected the harness to it?
    Check for vacuum leaks. Look under the snout of the S/C at the T and see if it's cracked. You can use carb or brake cleaner to spray around all the vac. connections to see if you hear a difference in the motor while it is running. If you find a spot that makes the motor change tone then that is a vac leak.
    As stated, water from the exhaust is normal. Now, the white smoke may or may not be normal. There is a chance that it's normal condensation in the air if you noticed this while it was cool outside. If it was 95* out and you see white smoke then you are burning coolant.
  17. #17 Re: Car idle jump and water from exhaust pipe
    the desert
    i just disconnected the harness. I replaced the vacuum lines so I don't think its a vacuum leak.
  18. #18 Re: Car idle jump and water from exhaust pipe
    The hesitation could be from the disconnected maf unless you just recently disconnected it for troubleshooting purposes.
  19. #19 Re: Car idle jump and water from exhaust pipe
    the desert
    I disconnected it for troubleshooting purposes
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Size of exhaust pipe before cat
    By ryanm in forum 5.3L V8 (LS4)
    Last Post: 07-20-2011, 06:27 PM
  3. oil in radiator, smoke and water from exhaust
    By xlemon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2010, 12:46 AM
  4. Fwi water in pipe
    By shanester in forum General Tech Discussion
    Last Post: 06-21-2009, 11:59 PM
