Thread: Mode Actuator Replacement?
Results 1 to 6 of 6
  1. #1 Mode Actuator Replacement?
    Dec 2011
    Cliffside Park, NJ
    The written instructions accompanying the mode actuator replacement direct removal and replacement from under the dash yet the image in the factory service manual shows everything being done from above, ex. putting the actuator arm on the rotating tab and installing a new tie from above. Any suggestions?
    I tried to do this from underneath per the written instructions and rotated the pivot by looping some string around the hook. Unfortunately, the tail end of the hook broke off when I got the actuator arm on the hook. Can I access the hook by removing the DIC so I can epoxy the tail end of the hook back on the rotating portion?
    Many thanks,
    Joe
  2. #2 Re: Mode Actuator Replacement?
    Sorry Joe..never did one of these before. Bump to the top.
  3. #3 Re: Mode Actuator Replacement?
    Dec 2011
    Cliffside Park, NJ
    Bill, Sometimes I think I'm the only one who has had a mode actuator fail. Thanks, Joe
  4. #4 Re: Mode Actuator Replacement?
    Apr 2009
    Fort Worth TX
    I've never heard of anyone having the pleasure of replacing this.
    This may be a historic moment for GPF. LOL
    Watch - mine will break tomorrow.
  5. #5 Re: Mode Actuator Replacement?
    Joe, you might be. The picture makes it look vacuum operated. Typically those don't fail, the vacuum from the motor gets lost somewhere on the way around the engine bay.
  6. #6 Re: Mode Actuator Replacement?
    Dec 2011
    Cliffside Park, NJ
    Bill, You're right. The actuator didn't fail and it is operated by vacuum. What broke is the thin metal arm which extends from the actuator and pushes against the rotating plastic pivot piece. I keep hoping that someone will share how to both best access the plastic tab so I can repair it and install the new actuator. It was a bear to get the new actuator attached the first time and I'm not going to try it again without some advice. Thanks, Joe
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Supercharger ACTUATOR???
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 08:25 PM
  3. Heat Actuator
    By Allen2000GP in forum Introductions/Noob Questions
    Last Post: 03-21-2012, 06:47 PM
  4. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
