Thread: removing ac belt lengh
Results 1 to 15 of 15
  1. #1 removing ac belt lengh
    Mar 2012
    does anyone know the correct length of the belt needed to remove the ac on a 2002 gtp??
    my ac clutch is gone and i cant stand to hear the noise its making... its also like a 500 dollar job, and honestly i dont care for ac anyway
    any help would be great
    Thanks all
  2. #2 Re: removing ac belt lengh
    Remove AC yourself with a 15mm wrench/ratchet...whatever it takes.
    Buy a AC delete kit from your local auto parts store for like 40 bucks and use the factory belt that is already on there.
  3. #3 Re: removing ac belt lengh
    Mar 2012
    seems there is no ac delete kits available in any of the parts suppliers books... do you happen to know a part # for one?? then maybe i could give them that, and they could look it up by that
  4. #4 Re: removing ac belt lengh
    its been done before, you need to search for one on the net maybe. wbs or even zzpoop should have it.
    rockauto may even have it.
  5. #5 Re: removing ac belt lengh
    Couldn't find it at a auto parts store but you can buy it from ZZPerformance for cheaper than the $55 it used to be from what I remember...
    ZZPerformance - AC Delete #ZZ-GPACD
  6. #6 Re: removing ac belt lengh
    Mar 2012
    thats for the 04 + style setup... my gtp is 02... different part
  7. #7 Re: removing ac belt lengh
    No, there is the Series II as the default option.
    Series III is a +10 dollar option.
  8. #8 Re: removing ac belt lengh
    Mar 2012
    ya i see that, my bad.... wondering if its available anywhere else, or just there?
  9. #9 Re: removing ac belt lengh
    Probably just there, I ebay'd it...well, I looked for a few minutes...lol.
    ZZP has fast shipping, it is worth it really...instead of wasting your time with a local parts store.
  10. #10 Re: removing ac belt lengh
    Mar 2012
    ya when i checked ebay the only listing i saw was someone saying it was listing for the 98 gtp.... and im not sure if that is the same as the 02, is it? you prob know better then i do
  11. #11 Re: removing ac belt lengh
    Anything AC related is all the same 97-03...as long as it is a 3800. Supercharged or not.
  12. #12 Re: removing ac belt lengh
    Mar 2012
    perfect, so then the listing
    87-03 Chevy Impala Grand Prix Sunbird A/C Bypass Pulley | eBay
    should work then?
  13. #13 Re: removing ac belt lengh
    Yeah, that works.
  14. #14 Re: removing ac belt lengh
    Mar 2012
    perfect, if thats the case, ill order one up today.... thank you so much for all this... ill let you know when it comes in and confirm it works
  15. #15 Re: removing ac belt lengh
    When you install it, just be sure to rip everything else out of the engine bay AC related...it really opens up space in there.
  1. Removing bbv.
    By Bluemagic in forum General Tech Discussion
    Last Post: 06-04-2012, 08:23 AM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. How should i go about removing this?
    By IBurnCamaros in forum Detailing Tips and Tricks
    Last Post: 04-27-2011, 10:49 PM
  4. Removing the AC and other obstructions?
    By brewcrew125 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-12-2010, 05:40 PM
  5. Removing Oil Pan
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 04:27 PM
