not one of us here are mind readers, well maybe Billboost is, but most of us need words put together in sentence form, with the whole story and something close to the proper terminology used for the parts you are referring to.
your quotes...
i can hear the vac pump pumping, what vac pump pumps on your car? you could be referring to 3 things if you dont know what you are talking about. or can make it clear.
is the check valve in the engine compartment? or inside the vehicle. what check valve?
also could my cam be causing low vacuum from excessive overlap? brakes seem to be harder to clamp down as well, not as snappy as most cars i have driven.
now where in the world in your first post do you say you bought it like this???????? been like this since day one???? where? how would we know?
so ill finish with your own line.
"just saying before you talk like a bad ass, try knowing what you talking about." <<<<<<<yes you need to do this.
ever think why 2 days went by with no response? and then you had to bump it? do you know why? no one knew wtf your were talking about, that's why.
