Quote Originally Posted by 850Fishing View Post
Same thing happened to me on the ac issue. Its the main vac line feeding the control modules under your dash. The 3 way vac valve on top of the supercharger has a thin black hard line that heads to the fire wall. Then runs along the fender near the battery then back to the firewall. Somewhere on that line it's either cracked or the coupler fittings that splice the line together are leaking. Inspect those real good. Hope this helps
thank you. exactly what i was looking for.
i was not talking about abs pumps, there is a vacuum diaphram under driver side footwell with vac line hooked to it.
i bought this car with them cam in it, been doing it from day one..
just saying before you talk like a bad ass, try knowing what you talking about.
