Thread: Help with rods plz
Results 1 to 11 of 11
Classy Pontiac Help with rods plz 06-06-2012, 10:04 PM
matt5112 Re: Help with rods plz 06-06-2012, 10:07 PM
Classy Pontiac Re: Help with rods plz 06-06-2012, 10:13 PM
matt5112 Re: Help with rods plz 06-06-2012, 10:14 PM
Classy Pontiac Re: Help with rods plz 06-06-2012, 10:18 PM
matt5112 Re: Help with rods plz 06-06-2012, 10:29 PM
gtpeddie Re: Help with rods plz 06-06-2012, 10:34 PM
matt5112 Re: Help with rods plz 06-06-2012, 10:37 PM
Classy Pontiac Re: Help with rods plz 06-06-2012, 10:41 PM
gtpeddie Re: Help with rods plz 06-06-2012, 10:42 PM
matt5112 Re: Help with rods plz 06-06-2012, 10:44 PM
  1. #1 Help with rods plz
    GTP Level Member
    Sep 2011
    Motown
    Alright I been reading everywhere and this was the best info I could find about the l26 rods.
    Engine Info/Differences
    The L67 and L32 have a 8.5 to 1 compression ratio
    The L36 and L26 have a 9.4 to 1 compression ratio
    The L67 and L32 have the fuel injector bosses in the heads
    The L36 and L26 have the fuel injector bosses in the LIM(lower intake manifold)
    The L32 and L26 have an Electronically Controlled Throttle
    The L67 and L36 have a Cable Controlled Throttle
    The L26 and L36 have one Belt
    The L67 and L32 have two Belts
    The L32 and L26 have a 4 bolt square throttle body bolt pattern
    The L67 and L36 have a 3 bolt triangle throttle body bolt pattern
    The L32 and L67 cars have a 3/4" Radiator
    The L36 and L26(Maybe) have a 5/8" radiator
    The L67 has a Gen III M90
    The L32 has a Gen V M90(the gen V is considered much more efficient)
    ****The Stock Pulley for both Gen III and Gen V is 3.8 inches in Diameter
    The L36 has a Plastic Upper intake
    The L26 has an Aluminum Upper intake
    The NA motors have the cam timing off one degree from the factory
    The SC pistons have more space between the piston top and top compression ring than the NA pistons
    The L32 and L26 engines have Powder Forged connecting rods and Moly Coated Piston skirts
    The L32 and L26 engines' heads flow slightly better than the Series II heads
    (thanks to slightly bigger valves and slightly better port design)
    What I was trying to find out was are the l26 rods the exact same as the l32. Reason being is because I plan on running nitrous in my l26 motor. I dont want a rod to fail over nitrous. In the facts I pasted above it says that the l32 and l26 rod are the same, are they the exact same or are they made the same way? Im asking many questions because I would rather be safe than sorry. thx for the help guys.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: Help with rods plz
    they're not the same.
    L26 are rumoured to be the weakest of the bunch.
    L32/26 are powder forged yes, but different rods.
    L32's are shorter and stronger. L26 are longer and weaker.
    You must use the same rods as pistons.
    N/A rods with N/A pistons and so on. But you can interchange the type of N/A rods and pistons.
  3. #3 Re: Help with rods plz
    GTP Level Member
    Sep 2011
    Motown
    Alrite that helped alot. thx man but by chance do you know how much the l26 bottom end can handle, as in torque and hp? thx
  4. #4 Re: Help with rods plz
    apparently (Aka take with grain of salt): any M90 build, its good.
    If going turbo, be afraid.
    N/A? Let 'er rip.
  5. #5 Re: Help with rods plz
    GTP Level Member
    Sep 2011
    Motown
    what about with nitrous?
  6. #6 Re: Help with rods plz
    I've got nothing.
    NEXT?
  7. #7 Re: Help with rods plz
    Jan 2012
    Philadelphia
    just curious doesnt really have anything to do with this but are L67 and L36 valve covers the same like would L36 valve covers work on a L67?
  8. #8 Re: Help with rods plz
    did you mean L32 and L67? If so, yes.
    But serious: never looked into 3800 + nitrous. Was a thread on it a while back, a serious one. Might want to try and find that.
  9. #9 Re: Help with rods plz
    GTP Level Member
    Sep 2011
    Motown
    Ok, ill try again lol. If not im gonna try and make this one the nitrous thread lol
  10. #10 Re: Help with rods plz
    Jan 2012
    Philadelphia
    L36 is the N/A 97-03 right? if so i did mean L36, i just wanted to seeif they were in case i go to a JY and see a set i was gonna grab them. L67 don't pop up around here that often and when they do there always stripped
  11. #11 Re: Help with rods plz
    They wont work.
    If you want a set of L67's i can send one out to you for shipping. They're painted black. Maybe red stripes. Can't recall. PM me if you want them.
  1. L32 Rods
    By ActionMatt in forum Wanted To Buy - Parts
    Last Post: 02-14-2012, 06:48 PM
  2. How much can i get for my car with rods gone?
    By jhamman in forum Introductions/Noob Questions
    Last Post: 01-29-2011, 10:04 PM
  3. rods
    By musiknjoyr in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 08:19 PM
