Thread: Ticking noise ?
Results 1 to 7 of 7
  1. #1 Ticking noise ?
    GT Level Member thegipper's Avatar
    grafton, wi
    Hey
    Sometimes when I start up my car, I get a ticking noise from under the hood. Its been doing it for about a month now. It doesn't always do it, maybe 35% of the time.
    So the other day I popped the hood when I heard the noise. Its always the loudest right at start up and gets quieter as it warms up. Usually within minutes. It eventually pretty much goes away.
    It sounds like its coming from the front of the engine. When I take the oil cap off, it sounds pretty clear that its coming from in there. I installed ER rockers about 10 months ago, and never had any issues.
    Does this sound like a bad rocker, loose rocker bolt? or could it just be a sticky lifter? Its not loud per say but its noticeable.
    I'm leaning towards a sticky lifter because it gets much quieter as it warms up. And it doesn't always do it either. I'm guessing if it was a rocker or rocker bolt it would be constant.
    Should I just run some seafoam in the oil before I change the oil next?
    Thanks for your help !
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  2. #2 Re: Ticking noise ?
    grafton, wi
    Wow. I figured I would get all sorts of responses. Maybe ill try to use that Lucas Oil stabilizer and see what happens.
    Dec 2010
    DMV
    Sounds like a lifter
  4. #4 Re: Ticking noise ?
    St. Louis
    I'd seafoam it then change the oil. It does indeed sound like a lifter.
  5. #5 Re: Ticking noise ?
    Aug 2012
    Mich
    Hey I got ticking noise going on. Has anyone had luck with any solutions? If its my lifters is that a really bad problem?
  6. #6 Re: Ticking noise ?
    Quote Originally Posted by monikay View Post
    start your own thread, and post a video of the ticking.
  7. #7 Re: Ticking noise ?
    Aug 2012
    Mich
    thanks I'm new to this site so I will just have to figure out how
  1. ticking noise
    By Toms04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2012, 02:04 AM
  2. what is this ticking noise?!?!?
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 07:36 AM
  3. l26 ticking noise...
    By Couch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2011, 12:05 PM
  4. ticking noise
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2011, 10:52 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
