Thread: What do you need to cam a engine?
Results 1 to 14 of 14
  1. #1 What do you need to cam a engine?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    So i have really been looking into getting a cam lately and i guess i keep finding these "hidden" requirements.
    So if i bought a (xp) cam what else would i need i read you need modified retainers double chains and other stuff orginially i wanted to get the xpz but it says you need modified heads and thats like 1,600 alone for the heads at zzp i just dont see what all i need.
  2. #2 Re: What do you need to cam a engine?
    Ohio
    xp cam....
    needed:
    cam.....derp
    installation kit from zzp there are 4 choices, pick one with the most ****
    105 springs
    modded retainers
    zzp valve seals
    timing set, stock replacement will be fine.
    have a nice day
  3. #3 Re: What do you need to cam a engine?
    Springs
    Valve seals
    Modded/Manley retainers
    Camshaft
    Front cover gasket
    LIM gasket
    SC gasket
    VC gaskets (with grommets)
    Reusable rocker bolts
    Valve spring compressor
    Air chuck to keep valves up with air compressor )at least 100psi)
    New timing chain
    RTV
  4. #4 Re: What do you need to cam a engine?
    Ohio
    bill filled my gaps......
    no homo
  5. #5 Re: What do you need to cam a engine?
    You had a few gaps.
  6. #6 Re: What do you need to cam a engine?
    Ohio
    i realize that...and you filled them lol mainly just misc gaskets.
    you could do new lifters too while you're in there...not required but if you want to then go for it..
    all together you're looking at about 900
  7. #7 Re: What do you need to cam a engine?
    Overnight parts from japan.
  8. #8 Re: What do you need to cam a engine?
    Ohio
    alright johnny tran
  9. #9 Re: What do you need to cam a engine?
    Do not buy ZZP valve cover gaskets.
    They do not fit and will leak.
  10. #10 Re: What do you need to cam a engine?
    Oct 2011
    then who
  11. #11 Re: What do you need to cam a engine?
    Feb 2008
    Quote Originally Posted by RideWithPride View Post
    then who
    x2 Felpro. Mine fit like ****, ended up actually getting caught when bolted down and had a slight tear and a massive leak right onto my headers..
  12. #12 Re: What do you need to cam a engine?
    St. Louis
    Fel-Pro
  13. #13 Re: What do you need to cam a engine?
    ZZP VC gaskets are made for their aluminum valve cover. Which are slightly smaller than a stock. They are also a harder rubber and dont' come with grommets.
    Here's ZZP's in a valve cover. Look at the bends.
    Their LIM gaskets are also goofy. They just don't fit right.
    Me, I personally buy GM LIM's, Fel Pro VC's (with grommets), depends on which charger I have/using/IC etc, fel pro TB, Dorman elbows. All sourcable local with discounts.
  14. #14 Re: What do you need to cam a engine?
    Feb 2009
    flintnasty MI
    i get gaskets at the dealer cheaper than at zzp...
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
