Thread: Howling Problem
Results 1 to 12 of 12
  1. #1 Howling Problem
    SE Level Member LRSLLC's Avatar
    May 2012
    Sandy Hook, CT
    Hello everyone.
    I just purchased a 2000 GTP with 101000 on it. It had a few issues that I have addressed however the newest is a howling sound only when I begin to accelerate regardless of what gear it is in. It seems most noticeable just as the boost gauge starts to show. The harder I accelerate the less it Howls. Does anyone have any ideas???? Any help would be greatly appreciated. Thank you.
    Dec 2010
    DMV
    Vacuum leak? You showing full boost?
  3. #3 Re: Howling Problem
    GTX Level Member blackflag's Avatar
    Virginia
    Do you have a cone filter? At certain throttle positions mine has a deep whistle. I guess you could call it a "howl".
  4. #4 Re: Howling Problem
    May 2012
    Sandy Hook, CT
    No vacuum leak and yes to full boost. The filter is a K&N. I just checked the supercharger oil level. It is low and likely shot. I ordered 2 bottles and will change it as soon as they arrive. Thanks for the input. I will keep you posted.
  5. #5 Re: Howling Problem
    May 2012
    Sandy Hook, CT
    Update. I have changed the supercharger oil, did an air intake mod to a cone filter, checked again for a vacuum leak and it still howls. What I did notice is that it seems to be coming from the rear of the car. I was slowly going down my road with the window down, pressed the pedal and sure enough it is coming from the rear. Anyone have any ideas?? Thanks.
  6. #6 Re: Howling Problem
    St. Louis
    Maybe a bad wheel bearing? That's about all that's back there that could howl like that.
  7. #7 Re: Howling Problem
    bad rear hub, or a bad tire.
    Dec 2010
    DMV
    Hub sounds about right.
  9. #9 Re: Howling Problem
    May 2012
    Sandy Hook, CT
    It only does it right when I start to give it gas and at any speed. The harder I accelerate the noise is much less. It almost seems as though it is the exhaust.........
  10. #10 Re: Howling Problem
    May 2012
    Sandy Hook, CT
    Like I've been saying. It only does it getting on the gas. Sure enough the leak in the exhaust that started as a howl is now a rotted through pipe. So now the question is do I just replace the cat and system after the cat or do the headers at the same time?? Decisions decisions.........
  11. #11 Re: Howling Problem
    St. Louis
    If your budget allows then I say headers, u-bend delete, new cat and leave the rest stock down the the mufflers.
  12. #12 Re: Howling Problem
    Look inside the resonator with a flashlight though.
    They can fail and peel inwards creating a larger restriction than the stock U bend.
  1. Grinding Howling Noise?
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 01-31-2012, 07:15 PM
  2. Howling Noise
    By Packer Fan in forum General Tech Discussion
    Last Post: 12-30-2011, 04:13 PM
  3. Howling in front of car
    By jeangreyfan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 11:25 PM
  4. Weird howling noise under dash?
    By hjz8785 in forum General Tech Discussion
    Last Post: 07-25-2011, 10:29 PM
  5. Car makes odd howling noise
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-20-2011, 01:50 PM
