Thread: Car wont start
Results 1 to 6 of 6
  1. #1 Car wont start
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    I went to start my car (2000 GT) and as soon as i tried to start it everything went dead. Its almost like its shorting out somehow. Interior lights work when doors are open and key is in off position. Interior lights shut off when I tap the brakes. Also cant lock or unlock the car with the key fob. Battery is fully charged.
  2. #2 Re: Car wont start
    check your battery cables and the ground on the bell housing of the trans. could also be a bad starter solenoid.
  3. #3 Re: Car wont start
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    also check for corrosion on cables. if all is well you could have a bad ignition switch
  4. #4 Re: Car wont start
    Dec 2011
    Michigan
    Cables were fine. forgot to mention when i tried to start the car there was a click. sounded like it was coming from the fusebox area. fuses were fine though
  5. #5 Re: Car wont start
    if you heard a click that was likely the starter. you can try to hit it with a hammer see if it works after 2 or 3 good hits. if it starts up after that you need a new starter.
  6. #6 Re: Car wont start
    Dec 2011
    Michigan
    Well turns out it was the battery. Really weird. Battery showed full charge when i tested it, but when i tried to jump it I was able to almost start it. Got a new battery in it and is running great.
  1. Car wont start !!!!
    By 2000pontiacgtp in forum General Grand Prix Discussion
    Last Post: 04-02-2012, 09:24 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
  4. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
