Thread: rear windows won't hold up
Results 1 to 10 of 10
  1. #1 rear windows won't hold up
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    My rear windows won't go up they keep falling down I wondering if this is a problem with the window motor or the regulator? And another thing my right rear window don't got power at all I already check the all the cables the go to the door and none if them show the have power is there a fuse I could check t
  2. #2 Re: rear windows won't hold up
    St. Louis
    Windows falling tells me the regulator is shot.
    Right rear window w/ no power is probably the drivers master switch. All power passes through that switch first IIRC, so if it's bad you won't get power to the individual window.
  3. #3 Re: rear windows won't hold up
    May 2011
    El paso tx
    Sorry but what's IIRC?
    So do you think I should replace the whole motor or just the regulator?
    And for the master switch do I replace the while thing or just for that window?
  4. #4 Re: rear windows won't hold up
    Antioch, IL
    If I remember correctly
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: rear windows won't hold up
    May 2011
    El paso tx
    Oh ok never thought about that
  6. #6 Re: rear windows won't hold up
    St. Louis
    If you can get just the regulator then do that. Most likely the motor is fine. Sometimes it's harder to find just the regulator separately. Check Rock Auto and Ebay.
    Don't recall if the master switch is multiple components or not. Haven't had mine off in a while. Someone else here should know the answer to that one. I'm almost positive it's all one switch even though it has separate buttons for the windows.
  7. #7 Re: rear windows won't hold up
    May 2011
    El paso tx
    Theirs an 05 at the junk yard with the motors and regulators doors are bend pretty bad but I think I could remove the regulators is there any special wey I have to remove them or just how they sit?
  8. #8 Re: rear windows won't hold up
    St. Louis
    I don't know what year your car is, but I would assume 04+. You need to remove the door panel, then there are 3 10mm bolts that hold the motor to the door, and 4 that hold the regualtor in the door. There are also 2 bolts (one on each end) that hold the glass to the regulator. Then just wiggle the regulator/motor assembly out one of the access holes in the door and there you go. Oh, and disconnect the wire harness to the motor before you remove it.
    If the door glass is all the way down then you won't be able to get to the bolts for the glass. I always do mine w/ the glass fully up w/ tape on it to keep it up as once the regualtor is removed the glass has nothing to support it and will drop quickly which could result in a nasty cut for you when your wrist or arm gets pinched under the glass and against the edge of the door frame. That area is sharp sp be carefull.
  9. #9 Re: rear windows won't hold up
    May 2011
    El paso tx
    Yes is an 04, Thanks ford man how do you disconnect the cable from the motor?
  10. #10 Re: rear windows won't hold up
    St. Louis
    The cable looks to be part of the regulator itself, so once you have the entire assembly out in your hands you should see a few bolts that hold the motor the mounting plate. Just remove these and pull the motor straight out trying not the disturb the gear in the regulator. Then just swap in a new reg. and give it a go.
    I've never had an 04+ in front of me so I'm just going off of memory and pics I've found so not 100% sure how or if the motor can be separated, but someone built it so it has to come off somehow.
  1. Lost powerlocks/windows/rear defroster/left blinker
    By bonz85 in forum General Tech Discussion
    Last Post: 11-04-2011, 06:07 PM
  2. how much can it hold?
    By 08grandprixgxp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2011, 01:13 PM
  3. i want to hold a gun...
    By noreasonwhyy in forum Off Topic Discussion
    Last Post: 01-03-2011, 04:13 PM
  4. Rear windows intermittently work
    By 98GT3800 in forum General Tech Discussion
    Last Post: 11-20-2008, 07:33 PM
  5. Rear windows not working
    Last Post: 06-28-2008, 12:14 AM
