Thread: Problem changing supercharger oil.
Results 1 to 6 of 6
  1. #1 Problem changing supercharger oil.
    May 2012
    Burlington, Wisconsin
    Well, I went to change my supercharger oil and I can't seem to get the bolt off of the supercharger. I'm using allen wrenches and none seem to fit right. Does anybody know what other options I have?
  2. #2 Re: Problem changing supercharger oil.
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I assume its a metric size.
    Are the corners rounded? If so, it may be time to use an extractor.
  3. #3 Re: Problem changing supercharger oil.
    May 2012
    Quote Originally Posted by mechguy View Post
    Yes they are rounded. What kind of extractor do you suggest using?
  4. #4 Re: Problem changing supercharger oil.
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    It should be a 3/16 allen key IIRC. Make sure the Allen Key is all the way into the bolt before attempting to turn, you dont wanna keep stripping tools. Mine was a but tough to get loose so i just put a closed end wrench on the end of the allen key to get leverage.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  5. #5 Re: Problem changing supercharger oil.
    Dec 2010
    Canada
    Depends on the size of the allen head. I don't recall what size it is. Most large hardware stores should sell single extractors of the right size.
  6. #6 Re: Problem changing supercharger oil.
    mine is a torx bit. looked like a Allen but after cleaning it up the points showed. i think it was a t-35 or t-40 not sure tho.
  1. Eaton M90 changing oil **PROBLEM**
    By mckillin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2011, 11:06 AM
  2. H@lp w/Changing SuperCharger Oil & Transmission Oil ( D.I.Y ? )
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 06:31 PM
  3. Changing the supercharger oil, how often and how?
    By boostedzx3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 02:27 PM
  4. Problem after changing battery
    By gamersdg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 07:05 PM
  5. i need help on changing supercharger oil
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 02:21 AM
