Thread: Problem after changing battery
Results 1 to 7 of 7
  1. #1 Problem after changing battery
    Feb 2010
    nj
    I just changed the battery in my 05 GP. Always started right up, now every time I go to start it the motor turns over about 15 times before firing. Didn't do anything but change the dead battery. When I bought it I matched CCA and everything, have no clue what could be causing it. ANY HELP? PLEASE
  2. #2 Re: Problem after changing battery
    Charles City, IA
    Did you arc a wire to anything or anything like that?
    SMGPFC Two Nipple General
  3. #3 Re: Problem after changing battery
    Feb 2010
    nj
    No, Everything went perfectly fine. Didn't arc a wire while taking them on or off. Didn't short anything while putting it back in. Didn't even have jumpers on it. Sat for the weekend went out to start and it was dead. Took my truck to work picked up a new battery on the way home from work and put it in.
  4. #4 Re: Problem after changing battery
    Charles City, IA
    Let it run for a while and drive it around. The pcm may need to relearn all the fueling and stuff. Drive it for a good 30 min and try starting it again. Also try just turning the key to on the off a few times to prime the fuel pump, you might have a fuel pump on the way out.
  5. #5 Re: Problem after changing battery
    Feb 2010
    nj
    Thanks I'll try it out and let you know. I figured it could be a problem with the computer resetting, but only drove for about 15 min. I tried the fuel pump already. The thing that gets me is when I let off the key while it is turning over, it keeps going until it starts(just found this out). It could be a type of safe mode for the pcm for a couple of cycles.
  6. #6 Re: Problem after changing battery
    Charles City, IA
    A lot of new cars do that. They do it every time they start.
  7. #7 Re: Problem after changing battery
    Feb 2010
    nj
    Finally got to drive the car for about an hour. Got back and let it sit for about 15 min. Went back out and it started perfectly fine. Thank you very much it was probably just the pcm getting it's new info.
  1. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  2. Battery terminal
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2009, 02:33 PM
  3. battery charging
    By grand2000prixgtp in forum Off Topic Discussion
    Last Post: 09-18-2009, 03:17 AM
  4. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
