Thread: Changing the supercharger oil, how often and how?
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Changing the supercharger oil, how often and how?
    SE Level Member boostedzx3's Avatar
    Mechanicsburg PA
    Never dealt with a supercharger before, im used to the tapped block with a turbo and a drain line into the pan. I guess it's not bad to do? I've got 123k on mine and I'm betting it's never been done.
  2. #2 Re: Changing the supercharger oil, how often and how?
    do it ever 30K miles.
    reading the owners manual works wonders.
  3. #3 Re: Changing the supercharger oil, how often and how?
    GT Level Member rolyat's Avatar
    OKC
    ^^Some people might not have an owners manual and would rather ask then buy one....
  4. #4 Re: Changing the supercharger oil, how often and how?
    I don't have one, but i have a digital copy.
    Want it? its for a 2002.
  5. #5 Re: Changing the supercharger oil, how often and how?
    Mechanicsburg PA
    I have one but I looked through it and didn't see that one. I'll have to look again.
  6. #6 Re: Changing the supercharger oil, how often and how?
    from 7-10 from my digital copy of the 02 manual under the 30 000 Mile section
    For supercharged engines only: Check the supercharger oil level and add the
    proper supercharger oil as needed (or every 36 months, whichever occurs
    first). See “Recommended Fluids and Lubricants” in this section.
    An Emission Control Service. (See footnote ).
    They say check and top up... but this is like gear oil, its gotta be changed.
  7. #7 Re: Changing the supercharger oil, how often and how?
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    This is the "how to" for changing the coupler, but it shows a good way to get the oil out.
  8. #8 Re: Changing the supercharger oil, how often and how?
    SE Level Member KMAN's Avatar
    Feb 2010
    Ontario
    I did mine in my 2006 GT and I used this siphon . I bought this car 3 weeks ago and I wanted to change the oil . I am glad I did, it was smelly and very dirty. I am sure the last owner never did. Pump out the old oil very fast.
  9. #9 Re: Changing the supercharger oil, how often and how?
    Feb 2010
    Chatsworth, CA
    I need to probably do it as well.
  10. #10 Re: Changing the supercharger oil, how often and how?
    Mechanicsburg PA
    so it's kind of like a diff being it's like gear oil, it really should be changed but chances are 1 in every 10 people maybe have actually done it as a preventitive maintenance step.
  11. #11 Re: Changing the supercharger oil, how often and how?
    yup.
    but its not really like gear oil in terms of its weight.
  12. #12 Re: Changing the supercharger oil, how often and how?
    Feb 2009
    Red Deer AB
    YouTube - Replacing a worn out supercharger coupler on 3.8 GM engines
    guess I forgot to add this part last time...
  13. #13 Re: Changing the supercharger oil, how often and how?
    GT Level Member Robroy04gtpcompG's Avatar
    ca
    I's super easy! I just changed mine, and it took almost 8 ounces of oil. It cost me $24 for two bottles from the dealer.
    Make sure your motor has cooled for at least two hours, as the pressure could shoot hot oil at you when you remove the plug bolt.
  14. #14 Re: Changing the supercharger oil, how often and how?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    turkey baster works for me.
    and beware of the stench
  15. #15 Re: Changing the supercharger oil, how often and how?
    Feb 2009
    Red Deer AB
    97-03 takes 6 oz is that different in the 04 +? or did you over fill it?
  16. #16 Re: Changing the supercharger oil, how often and how?
    People keep saying its 6 fl oz yet others say it takes 8.
    I think the issue is, how much did you get out?
  17. #17 Re: Changing the supercharger oil, how often and how?
    Feb 2009
    Red Deer AB
    good call. But GM, and zzp says 6 it takes 6oz
  18. #18 Re: Changing the supercharger oil, how often and how?
    GTP Level Member tazyboy28's Avatar
    home town
    had to bring this b ack from the dead cuz i was curious on which supercharger oil to use. ZZP has there brand for 10 dollars for i think 8 or 10 ounces, and they also sell GM oil for 7 dollars a bottle of 4 ounces.
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  19. #19 Re: Changing the supercharger oil, how often and how?
    Just buy the GM oil...do it right the first time. Don't help Zoomer Igloo's crap service fund.
    Mine took nearly two bottles...and IIRC, each bottle is 4 ounces...so yes, 2.
  20. #20 Re: Changing the supercharger oil, how often and how?
    home town
    cool beans . . .
  1. H@lp w/Changing SuperCharger Oil & Transmission Oil ( D.I.Y ? )
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 06:31 PM
  2. Changing The Set-Up Of My Gun / Gun Pictures... Obviously
    Last Post: 10-11-2009, 09:21 PM
  3. i need help on changing supercharger oil
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 02:21 AM
  4. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  5. changing supercharged oil
    By nemesis in forum General Tech Discussion
    Last Post: 08-06-2008, 12:27 PM
