Thread: Cradle bolts
Results 1 to 13 of 13
  1. #1 Cradle bolts
    Barksdale AFB, LA
    Question for those who know a lot about how the cradle should be handled.
    My cradle bolts are loose again. I want to tighten them up and add some thread locker. Is it safe to put the front of the car on jack stands, where the jack stands are under the mid points of the cradle (next to the control arms)? Then, I would remove one bolt at a time, apply locker, and torque.
    If I have to, I can wait for the chassis lift to become free and I think I have access to a type of support fixture. Not sure.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Cradle bolts
    Oklahoma
    It is perhaps my over cautious nature to such things but I used 4 jack stands to support the front end on my car when I started the engine and tranny pull. Im sure what you are proposing should be good, but I was concerned about all that weight. I was just going to put the jack stands at the jack points under the doors, but all that weight free hanging like that gave me pause. So I used 4 stands put right at the mounting points for the cradle.
    'Course, now when I go to pull the cradle that will have to change but there also wont be all the weight there either with the engine and tranny out. But again, Im over cautious about such things, so keep that in mind as well.
  3. #3 Re: Cradle bolts
    Barksdale AFB, LA
    I've never heard a peep from two jack stands with the front of the car's weight. The ones I use at the shop... one could hold up my entire car and then some. They're fine.
    My main issue is with supporting the front by the cradle while I take out one bolt at a time. Seems safe in my mind, but I don't want it shifting or becoming misaligned or something.
    Thoughts?
  4. #4 Re: Cradle bolts
    Oklahoma
    Quote Originally Posted by Sabrewings View Post
    Thoughts?
    If you are taking the bolts out one at a time, I dont believe anything would shift around on you.
  5. #5 Re: Cradle bolts
    Apr 2008
    Chillin at the Beach , VA
    Take it as you will, but if it was me, I'd also put some stands under the rear so that the car would continue to sit flat and not angled down in the rear. Just my thoughts on it. When I droped mine, I tried to keep the car as level as I could.
  6. #6 Re: Cradle bolts
    Barksdale AFB, LA
    Quote Originally Posted by BADAZGTP View Post
    If I'm gonna do all that, I'll just put it on the chassis lift and get it over my head. Thanks for the advice, though. Good point.
  7. #7 Re: Cradle bolts
    Apr 2008
    Yea, when I did mine, I got lucky. My brother had a lift in his shop at wotk that sits even with the floor. Pulled off the front of the lift to where the cradle would clear, strapped the back end down and put up the center jack. Lifted the car grabed the fork lift and was able to drop the engine and tranny all at once. Makes it easy when you have equipment like that.lol!!!
  8. #8 Re: Cradle bolts
    Moore, Oklahoma
    Anyone one the specific torque ft/lbs for the cradle bolts?
    Shawn W. Larsen
  9. #9 Re: Cradle bolts
    Bastard Reptile's Avatar
    Kansas City, MO
    I've loosened the bolts on the back before with jackstands on the radiator support end, I do this to lower the cradle a bit to put in the GMPP sway bars....and I've never had a problem. Taking one bolt out at a time will not be any big deal at all.
    GM shows torque specs for the front at 107ft/lbs and the rear at 118 ft/lbs
  10. #10 Re: Cradle bolts
    Feb 2008
    Quote Originally Posted by Reptile View Post
    X2
  11. #11 Re: Cradle bolts
    Donating Users blowfishRus6's Avatar
    g.a.
    what does the common poping noise come from usally?? after i went to the track my car started to pop when taking off. i then got hit in my wheel and had tie rods and cv joints replaced. at first i thought it was the motor mount but those were replaced and its actually worse now. the mec. said maybe it was the bushings on the struts, but i keep hearing about these cradle bolts. could they be the problem to my poping??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: Cradle bolts
    Feb 2008
    Quote Originally Posted by blowfishRus6 View Post
    Blowfish,
    It has been said that the cradle bolts were not torqued to spec from the factory. Go ahead and put a torque wrench on them and tighten them to specs. It is possible that could fix your symptoms.
    On the other hand, it is very common for failed strut mounts to make those same "knocking" or "popping" sounds. Check them out too.
  13. #13 Re: Cradle bolts
    g.a.
    good info, thanks blown97
    its slow.
  1. Installing Cradle (cradle alignment pins)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2008, 05:47 PM
  2. What do I have to watch on the power steering when dropping the cradle?
    By xxmattfxx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-07-2008, 11:57 AM
  3. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
  4. Tightening cradle bolts
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2008, 11:06 PM
