Quote Originally Posted by blowfishRus6 View Post
what does the common poping noise come from usally?? after i went to the track my car started to pop when taking off. i then got hit in my wheel and had tie rods and cv joints replaced. at first i thought it was the motor mount but those were replaced and its actually worse now. the mec. said maybe it was the bushings on the struts, but i keep hearing about these cradle bolts. could they be the problem to my poping??
Blowfish,
It has been said that the cradle bolts were not torqued to spec from the factory. Go ahead and put a torque wrench on them and tighten them to specs. It is possible that could fix your symptoms.
On the other hand, it is very common for failed strut mounts to make those same "knocking" or "popping" sounds. Check them out too.
