Thread: GTP, Problem?, Only one wheel pulls.
Results 1 to 9 of 9
  1. #1 GTP, Problem?, Only one wheel pulls.
    May 2012
    Kentucky
    I have a 1998 gtp, i am normally easy on the car but today i got a wild hair and did a little burnout. Only one wheel pulled and it pulled to the right, also i have noticed when driving it slightly pulls to the right. Are both wheels supposed to spin or just one?
  2. #2 Re: GTP, Problem?, Only one wheel pulls.
    Ohio
    we dont have a posi/limited slip so only the one wheel will spin.
  3. #3 Re: GTP, Problem?, Only one wheel pulls.
    Saratoga NY
    Quote Originally Posted by 99pgpgt View Post
    So if im at the track with slicks or on the street, i can always light up both tires...i must have "posi"?
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  4. #4 Re: GTP, Problem?, Only one wheel pulls.
    Quote Originally Posted by gmpowered View Post
    It wasn't availabile unless you added it from Quaife, EP, GM Torsen or an Intense LSD. It was never available on a factory transmission. Likely you have enough power to break both free.
  5. #5 Re: GTP, Problem?, Only one wheel pulls.
    Saratoga NY
    It wasn't availabile unless you added it from Quaife, GM Torsen or an Intense LSD. It was never available on a factory transmission. Likely you have enough power to break both free.
    I was being sarcastic bill.
    I believe power has little to do with it, Its simple TQ biasing in an open diff.
  6. #6 Re: GTP, Problem?, Only one wheel pulls.
    May 2012
    Kentucky
    Thanks for the help guys. Im kinda new to grand prixs. mom has had one for 2 to 3 years, and i just bought one with the wiring harness and injectors burnt of and fixed it. I love these cars but i dont know a whole lot about them.
  7. #7 Re: GTP, Problem?, Only one wheel pulls.
    With equal traction typically you'd get both wheels. Although this is not guaranteed, as GPGT says.. we don't have posi.
  8. #8 Re: GTP, Problem?, Only one wheel pulls.
    Ohio
    yeah, sometimes you can get both wheels going, but taking into consideration the crown of the road or other conditions like that, whichever wheel has less traction is going to spin
  9. #9 Re: GTP, Problem?, Only one wheel pulls.
    Ohio
    or engineered performance still makes their lsd. but, like bill stated...you obviously have enough power to break both loose
  1. Wheel Alignment and car still pulls badly to the right
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 10-03-2011, 09:03 PM
  2. Steering Wheel problem
    By tdm571 in forum General Tech Discussion
    Last Post: 04-09-2011, 01:16 PM
  3. Back wheel problem :'(
    By SIEBS in forum Tires & Wheels
    Last Post: 01-10-2011, 03:08 AM
  4. 2nd gear pulls...
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 12-31-2010, 11:01 PM
  5. Steering wheel problem...
    By TMOTA503 in forum General Tech Discussion
    Last Post: 09-09-2008, 07:02 PM
