Thread: Steering Wheel problem
Results 1 to 9 of 9
  1. #1 Steering Wheel problem
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    I was able to find a steering wheel in the junkyard with the audio controls on it and went to install it in my car. I've got the puller attached to the steering wheel cranking the nut when I hear a crack. At first I though it was one of the puller legs. No such luck. The steering wheel cracked. Now my steering wheel is off, but the sleeve thats molded into the steering wheel is still stuck on the steering column. I need some suggestions on how to get that sucker out of there.
  2. #2 Re: Steering Wheel problem
    St. Louis
    Do you have a slide hammer? Might be able to pull it off with that.
  3. #3 Re: Steering Wheel problem
    Lakeside Park, KY
    No, but I could rent one from AZ. The problem would be getting in behind the sleeve to get it off.
  4. #4 Re: Steering Wheel problem
    can you heat it up with out melting your column? and is there any thing left to get another type of puller on it?
  5. #5 Re: Steering Wheel problem
    Lakeside Park, KY
    The sleeve isn't that thick I'll see if AZ might have something. There's too much plastic right there to try and heat it up.
  6. #6 Re: Steering Wheel problem
    St. Louis
    I assume the sleeve is metal (haven't seen the inside of my wheel before). Could you get in there with a dremel tool and just cut slots on opposite sides (like cutting it down the middle but w/o going through the shaft) and then use a chisel or punch to crack it in half around the steering shaft?
    If done right you shouldn't damage the shaft.
  7. #7 Re: Steering Wheel problem
    ^^this sounds like a good plan...
  8. #8 Re: Steering Wheel problem
    Lakeside Park, KY
    I keep forgetting about my dremel. I'll give that a shot in the morning and let you know how it goes.
  9. #9 Re: Steering Wheel problem
    Lakeside Park, KY
    OK Class. Everybody repeat after me. The Dremel IS your friend.
  1. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
  2. Steering wheel...
    By SiDeWaYz in forum Visual/Body Modifications
    Last Post: 07-21-2010, 10:45 PM
  3. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
  4. Steering wheel problem...
    By TMOTA503 in forum General Tech Discussion
    Last Post: 09-09-2008, 07:02 PM
