Thread: There is a happy couple in my dash?!
Results 1 to 8 of 8
Kolton Lock There is a happy couple in my... 05-29-2012, 09:09 AM
ctracer Re: There is a happy couple... 05-29-2012, 09:12 AM
jteske88 Re: There is a happy couple... 05-29-2012, 09:20 AM
Scottydoggs Re: There is a happy couple... 05-29-2012, 09:46 AM
Kolton Lock And how do I fix that?!?! 05-29-2012, 11:58 AM
Scottydoggs Re: There is a happy couple... 05-29-2012, 12:06 PM
Kolton Lock Jteske88 yes I have the dual... 05-30-2012, 06:49 AM
Scottydoggs Re: There is a happy couple... 05-30-2012, 08:42 AM
  1. #1 There is a happy couple in my dash?!
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Yeahhh..no really though here is this noise coming from my dash.
    its less loud in person and sounds much more like a bed squeaking
    hehehe are we thinking Squirrel cage?
    or something else seeing as it doesnt happen solely from heater/ac running
  2. #2 Re: There is a happy couple in my dash?!
    new britain, ct
    LMAO
    07 Black GXP.
  3. #3 Re: There is a happy couple in my dash?!
    Yoga city
    you have dual climnate control?
  4. #4 Re: There is a happy couple in my dash?!
    sounds like a blend door actuator going nuts. mine would make a noise like that, then they stopped working all together.
    Mar 2012
    Minneapolis MN
  6. #6 Re: There is a happy couple in my dash?!
    you have 2 of them, on is on the pass side and the other is on the driver side, the pass side remove the glove box and look left, and you will see it, the driver side is a bit harder, you take off the food shield, the plastic under the steering wheel,the steel knee bolster thing, 4 bolts, this is just so you can kinds see it, you get to it from the bottom.
    i would get to them or the easy one, and put your hand on it and see if you can feel it turning back and fourth. the bottom hole you can see/feel it turn when its working.
    driver side.
    Mar 2012
    Minneapolis MN
    Jteske88 yes I have the dual climate control
  8. #8 Re: There is a happy couple in my dash?!
    you take the 2 little bolts off the actuator, and replace it. if thats your problem.
  1. If I had a couple G's..
    By JGSuperCharged in forum Off Topic Discussion
    Last Post: 08-12-2011, 12:22 AM
  2. Couple ?s
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-15-2010, 12:14 AM
  3. Couple Questions!
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 08:30 PM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. Need a couple PN's.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-02-2008, 09:55 AM
