you have 2 of them, on is on the pass side and the other is on the driver side, the pass side remove the glove box and look left, and you will see it, the driver side is a bit harder, you take off the food shield, the plastic under the steering wheel,the steel knee bolster thing, 4 bolts, this is just so you can kinds see it, you get to it from the bottom.
i would get to them or the easy one, and put your hand on it and see if you can feel it turning back and fourth. the bottom hole you can see/feel it turn when its working.
driver side.
