Thread: Loss of boost after plug wires change?
Results 1 to 14 of 14
  1. #1 Loss of boost after plug wires change?
    Dec 2010
    DMV
    Ok I changed my spark plug wires this Morn and I was going to tidy up my vacuum wires so I removed the vacuum lines by the front valve cover and the one to the right of it. Got short on time and hooked them back up because I had to go. Ok now I have three bars of boost. Confused? Usually it fills right up. Now I'm getting three bars.
  2. #2 Re: Loss of boost after plug wires change?
    re check everything.
    maybe a line cracked.
  3. #3 Re: Loss of boost after plug wires change?
    Texas
    did you uplug the BBV sensor? Sounds like it's either unpluged or the vacuum line was not put back on it.
    85 Corvette
    01 TA
    03 Z06
    Dec 2010
    DMV
    Ok I'll check everything out in a few.
    Is it ok to drive if I can't find the issue? As long as I stay off the boost?
  5. #5 Re: Loss of boost after plug wires change?
    Jan 2012
    Philadelphia
    i installed a boost gauge and it seems a little slower would that be because there is more vacuum line? just curious
    Mercer, Pa
    Quote Originally Posted by gtpeddie View Post
    The blower displaces 90 cubic inches per revolution. The volume of the the vacuum line is less than 1 cubic inch. At idle, 1000 rpm(easy math), the blower is moving 90,000 cubic inches per minute. Yes more volume but you would never be able to tell the slight difference.
  7. #7 Re: Loss of boost after plug wires change?
    Banned
    CT
    ...must...resist....incorrect...statements........ ..............
    OP check the BBV as already said!
    Dec 2010
    DMV
    Ok checked hoses on bbv. Everything looked fine. Any other suggestions? Ive never had this problem. Should I remove all the hoses and reconnect them?
  9. #9 Re: Loss of boost after plug wires change?
    Donating Users moddman's Avatar
    Midwest
    As someone already stated you might have a tiny crack in one of the hoses.....that you moved.....just a guess check the tee under the super charger snout.......that is a big culprit.......also if you have a vacuum gauge handy hook it up and see the vacuum at idle and when you rev it.......it should be high at idle and then go down really fast when you rev it and then hold steady.....
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
    Dec 2010
    DMV
    Ok I'll check in the am. Thanks
  11. #11 Re: Loss of boost after plug wires change?
    Banned
    CT
    Sorry I didn't read your whole post originally... You're likely not seeing any difference in boost pressure, but you may have cracked or broken vacuum line going to the Map sensor. You also may have disconnected the line going to the MAP sensor. This is what the PCM references for boost that you see on your gauge.
    The map sensor is located in the back of the engine bay near the fuel rail and above the valve cover.
    Dec 2010
    DMV
    The culprit! Thanks guys. Now the elbow is broken under the map sensor lol. Oh how I love thee lol
    Dec 2010
    DMV
    I still has leak. Smh. Lol this is ridiculous.
    Dec 2010
    DMV
    Back to this, ok finally found the leak. Vacuum is 19.5 at idle. It used to be 15.2. Great? Right? No.
    Now the bbv is stopping boost. Took lines off and instantly got full boost Lol. How can I resolve this? Do I need a new BBV?
  1. ZZP Plug Wires
    By 00RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2010, 11:28 AM
  2. Plug Wires?????
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-10-2009, 08:42 AM
  3. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  4. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
