Thread: Wiring Problem
Results 1 to 4 of 4
  1. #1 Wiring Problem
    Grand Island, Nebraska
    Ok so while I was wiring my wideband I must have hit something. My fuel level gauge no longer works and neither does my throttle position sensor. I changed the throttle position sensor and its still the same. I am at 0% throttle position no matter what according to HPTuners. I have a little light bulb volt tester thing, and I got the pins on the maf and IAC to light the bulb up but the TPS wouldnt light it up. The fuel gauge will go up like when i first turn the car to ON, but after that it goes right down as low as it can. I think my car is in limp mode now though because it wont shift until like 4k rpm. Im throwing codes for fuel sender low voltage, TPS intermittent voltage, TPS low voltage, and fuel sender high voltage, or something like that. I really dont want to trace down the TPS wire, is there something else i should check?
  2. #2 Re: Wiring Problem
    I figured it out. I'm an idiot and twisted all the EGR wires together.
  3. #3 Re: Wiring Problem
    Quote Originally Posted by JoRoW99 View Post
    I'd have to have said..no, keep on dealing with the issue if you don't wanna track down the issue.
    I'm happy you figured it out. Did you blow a fuse?
  4. #4 Re: Wiring Problem
    No surprisingly. I think i just grounded the 5v reference circuit that goes through the TPS and MAP sensor.
  1. led wiring help
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 04:13 PM
  2. HUD wiring problem
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 10-22-2010, 10:02 PM
  3. wiring help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-24-2010, 11:00 AM
  4. Few Q's about wiring
    By Joe in forum Audio, Security & Visual Electronics
    Last Post: 10-13-2009, 12:58 AM
  5. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
