Thread: Cold Air Intake -- PCM in way
Results 1 to 20 of 27
  1. #1 Cold Air Intake -- PCM in way
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    Alright I'd like to put a cold air intake on my 1997 gtp but when I tried to take my stock air filter off I found out that the computer is located inside the box.
    How would I solve this problem?
    I'm asking this because I'm fairly certain that the pcm can not get wet, and it needs good ventilation. If I just remove the box and mount it to the body somewhere, it would for sure get wet and if I keep it in that box and seal the box up then it will for sure over heat.
    *** I am aware that there are 10000 threads about this and I did search before making this topic but I could not find a single thread that answered my questions. I noticed several people just mounting it somewhere on the body, but what if it gets wet?
    Here is a picture of my cold air intake and the old air filter box and pcm. (I don't need to remove the box to use my cold air intake. I just wanna know what to do with the PCM)
  2. #2 Re: Cold Air Intake -- PCM in way
    Jun 2011
    The PCM will be fine without the box.
    Just Zip-tie it down somewhere.
  3. #3 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    Quote Originally Posted by E IN v Y View Post
    What about water?
    I regularly wash my car (which includes the engine compartment)
  4. #4 Re: Cold Air Intake -- PCM in way
    Jun 2011
    Everyone here that has HAI has their PCM like that.
    The PCMs are weatherproof not waterproof... and the air box is not waterproof.
    ...so far no one here has had any problems running it like that.
  5. #5 Re: Cold Air Intake -- PCM in way
    GTP Level Member
    Nov 2011
    Kansas
    My PCM sits on the ledge below the intake. It is velcroed down and I wash my engine bay regularly. Stuff in the engine bay is made to get a little wet.
  6. #6 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    So should I just keep it in the box then since it isn't in the way anyways?
  7. #7 Re: Cold Air Intake -- PCM in way
    Florida
    I had mine sitting on a rubber pad so it wouldnt get knocked around too bad, and had 2 big ass zipties holding it down...Never had an issue with water, and I regularly washed the engine bay.
  8. #8 Re: Cold Air Intake -- PCM in way
    GTP Level Member
    Nov 2011
    Kansas
    I would lose the box and redo your intake personally.
  9. #9 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    Quote Originally Posted by develand View Post
    Well this would be free if I kept it like this haha. What benefits do I get from making my own/buying an aftermarket?
  10. #10 Re: Cold Air Intake -- PCM in way
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Quote Originally Posted by Bologna View Post
    Here is a simple thread (you couldnt find any , about DIY intake and by the way PCM could just be ziptied.) Waste of money on buying CAI
    http://www.grandprixforums.net/simpl...res-33351.html
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  11. #11 Re: Cold Air Intake -- PCM in way
    Jun 2011
    Its not that hard and it looks like you already have a filter.
    Just make your own if you want to redo it.
    FYI you can get beast 9" filter for 20$.
  12. #12 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    Quote Originally Posted by compgjoe2793 View Post
    Sorry to be kinda an ass, but does that thread answer my questions? No it doesn't. And I did look at that thread already.
    Well I just feel safer with the computer in the box lol. And Really what's wrong with the stock one that makes it so bad and makes PVC pipe better? The only difference I see is maybe looks and that you can fit a bigger filter on it.
  13. #13 Re: Cold Air Intake -- PCM in way
    GTP Level Member
    Nov 2011
    Kansas
    BETTER FLOW!!!!!!! Your car likes to breathe. The more air you can get in, the better. The less turbulence also helps.
  14. #14 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    How do you get better flow? Are you referring to the location at where the filter is? Because if you are, wouldn't mine get better flow because it'll be right behind the grill on my car?
    If you are talking about the inside of the stock tube and the inside of a PVC tube, I doubt that makes much difference on flow lol.
  15. #15 Re: Cold Air Intake -- PCM in way
    Jun 2011
    Your current setup looks like it has a 90 degree bend in it.
    Id just stick to the stock air box then.
  16. #16 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    That it does, I forgot about that bend.
  17. #17 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    Alright I will remove my box and put my pcm somewhere safe and mount it securely and make my own cold air intake and get a big 9" filter.
    Thanks for your help guys, I just assumed that the pcm couldn't get wet.
  18. #18 Re: Cold Air Intake -- PCM in way
    GTP Level Member
    Nov 2011
    Kansas
    Woooooooooo!!!!!!!!
  19. #19 Re: Cold Air Intake -- PCM in way
    Jun 2011
    Just dew you... it is your car.
    We are here to assist you and are only trying to help.
    I would suggest this filter. AEM 9"X4" CONICAL DRYFLOW AIR FILTER ELEMENT 21-2059DK | eBay
  20. #20 Re: Cold Air Intake -- PCM in way
    Oct 2011
    Illinois
    Thanks for the suggestion and the link. I love links lol
  1. Cold Air Intake
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 03-09-2012, 09:39 PM
  2. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  3. Cold Air Intake
    By ljmonnin12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2010, 10:18 AM
  4. Cold Air Intake
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:25 PM
