You just plug the thing in... would probably be wise to have a tuner/scanner available before you go hard with it too much though... Will does good work but every car is different, with different mod levels, and you never know when you might be knocking a little.
He should've sent you a little packet with the pcm, read it and understand it... it tells you all you need to know.
