Thread: Problem with heater & Air control
Results 1 to 4 of 4
  1. #1 Re: Problem with heater & Air control
    the actuator is on the sides of the hvac control box under the dash in front of the console. but that just controls the heat or cold air. what you may need to look at is the vacuum operated pump. in the lower right of the pic with the vac line coming off it. ( you have one on each side) you also have a vac line under the hood that goes to this, its runs from under the windshield cowl down the pass side fender, and across the front of the car to a round ball in the driver side bumper. check that line for leaks or breaks. its hard plastic.
    to see these pumps, you need to remove the glove box and to the left you will see it, the d/s is harder to get to, the plastic trim under the steering wheel needs to come off then the steel knee bolster, and the foot cover under by your feet, look to the right and its right up front.
    i'd check under the hood before tearing all this apart to look at it, if you find nothing under the hood then take a look at the pumps, if you suck or blow into the line it should make it work. or at least feel vac or blowing from the line off the pump when the car is running and operating the controls.
    the pass side floor wet heres that link http://www.grandprixforums.net/water...-fix-6961.html
  2. #2 Re: Problem with heater & Air control
    May 2012
    Ohio
    Thanks for the response it really helped. I wired the passenger side open so the air conditioning is working much better, it was all coming out down by her feet. I couldn't find the main line to check it. Maybe I have to remove stuff under the front of the car to see it. So what piece would you think is most likely bad? Since none of the air direction - diversion controls seem to be working. It switches from heat to air controller and the blower works.
  1. A/c heater climate control
    By gman2000watts in forum General Tech Discussion
    Last Post: 10-21-2011, 09:18 PM
  2. heater control
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 06-11-2011, 01:16 AM
  3. Heater/ac control
    By Sameer in forum How To Write-Ups/Tech Tips
    Last Post: 10-25-2009, 08:08 PM
  4. Heater Control
    By TMC in forum General Tech Discussion
    Last Post: 11-27-2008, 07:42 PM
