Thread: where to run wiring for aftermarket guages
Results 1 to 6 of 6
  1. #1 where to run wiring for aftermarket guages
    Jun 2011
    Sheboygan
    where is the best place to run vacuum line, fuel pressure, and oil pressure wires through the firewall, is there a convenient hole I could run them through?
    1998 Red 4 door GTP
    Ported & Polished S/C with a 3.4 zzp mps
    3" catted d/p from zz
    ZZP 1.0 PCM 180 T/S CAI AL 104s
  2. #2 Re: where to run wiring for aftermarket guages
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    ye pull up some of the carpet on the passenger side floor and find the hole
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: where to run wiring for aftermarket guages
    Jun 2011
    Sheboygan
    Thanks, with my ported blower, 3.4 pulley, downpipe and cai i am seeing 9.5lbs of boost and 16 - 17 inches of vacuum. Does that seem accurate for my setup and 173,000 miles
    1998 Red 4 door GTP
  4. #4 Re: where to run wiring for aftermarket guages
    Oct 2011
    Michigan
    the boost seems close i need more info though like where you live exactly? you height above sea level affects the boost you see and i dont know about fuel pressure i dont measure that
  5. #5 Re: where to run wiring for aftermarket guages
    Jun 2011
    Sheboygan
    I live in wisconsin. I dont know exactly what elevation i am at though
    1998 Red 4 door GTP
  6. #6 Re: where to run wiring for aftermarket guages
    Ocala, FL
    Quote Originally Posted by Cobras 98 Prix View Post
    Sheboygan, wi?
    You are somewhere around 600-700 feet.
  1. Special wiring harness for aftermarket stereo for newer gp
    By MattTheBaker123 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2012, 12:28 AM
  2. Aftermarket Head Unit Wiring Help?
    By beams75 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2011, 04:52 PM
  3. wiring harness aftermarket stereo
    By LeThAlREMiX in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2011, 12:41 AM
  4. aftermarket fuel gauge wiring
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:09 PM
