Thread: PLOG install not going well
Results 1 to 19 of 19
tod1d PLOG install not going well 05-12-2012, 06:12 PM
Fivefingerdeathpunch Re: PLOG install not going... 05-12-2012, 06:14 PM
tod1d Re: PLOG install not going... 05-12-2012, 06:17 PM
ill12will8 Re: PLOG install not going... 05-12-2012, 06:45 PM
ill12will8 Re: PLOG install not going... 05-12-2012, 06:43 PM
dpzelenak Re: PLOG install not going... 05-12-2012, 06:45 PM
tod1d Re: PLOG install not going... 05-12-2012, 07:05 PM
Fivefingerdeathpunch Re: PLOG install not going... 05-12-2012, 07:08 PM
tod1d Re: PLOG install not going... 05-12-2012, 07:16 PM
bps02gtp Re: PLOG install not going... 05-12-2012, 07:28 PM
FriboRage Re: PLOG install not going... 05-12-2012, 11:21 PM
Tuner-Extraordinaire Re: PLOG install not going... 05-12-2012, 11:31 PM
bps02gtp Re: PLOG install not going... 05-12-2012, 11:31 PM
Swiggles If one bolt is going in at an... 05-13-2012, 02:26 PM
dazedandconfused Funny **** there guy 05-13-2012, 02:36 PM
Tuner-Extraordinaire Re: PLOG install not going... 05-15-2012, 02:37 PM
BillBoost37 Re: PLOG install not going... 05-14-2012, 06:32 AM
tod1d Re: PLOG install not going... 05-14-2012, 06:45 AM
BillBoost37 Re: PLOG install not going... 05-14-2012, 07:08 AM
  1. #1 PLOG install not going well
    May 2008
    Winnipeg, MB
    I can't get the PLOG lined up with the bolt holes in the block, its the two for the middle cylinder that are off their mark.
    2007 Pontiac Grand Prix
  2. #2 Re: PLOG install not going well
    Did you buy it new?
    And thats very odd that its not lining up.
  3. #3 Re: PLOG install not going well
    May 2008
    Winnipeg, MB
    Its never been used before.
  4. #4 Re: PLOG install not going well
    GT Level Member ill12will8's Avatar
    DC/MD
    also try to install those bolts first
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  5. #5 Re: PLOG install not going well
    DC/MD
    you moved everything out the way like oil dipstick?
  6. #6 Re: PLOG install not going well
    other bolts lose?
    SMGPFC Member #10
  7. #7 Re: PLOG install not going well
    May 2008
    Winnipeg, MB
    after I took that picture I tightened the three bolts that I can use, one other one snapped on me, it was going in on a bit of an angle
  8. #8 Re: PLOG install not going well
    Send it back from where you bought and show them the pictures and complain.
  9. #9 Re: PLOG install not going well
    May 2008
    Winnipeg, MB
    how well does ZZP stand behind their products?
  10. #10 Re: PLOG install not going well
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    never tighten a bolt on anything until you have all the bolts started and straight. even if its furniture that you're putting together. just a little tip. that is weird tho.
  11. #11 Re: PLOG install not going well
    Pennsylvania
    On ZZP's site they describe a 1 year return policy on defective merchandise. You should have no problem at all returning this if the bolt holes are tapped in incorrect places.
    Sport Edition Kv5 18x8
  12. #12 Re: PLOG install not going well
    Out West
    Should have gotten headers.
    Whine with your Cheese?
  13. #13 Re: PLOG install not going well
    Nov 2010
    Illinois
    lol!
    Quincy, Mass
    If one bolt is going in at an angle it's going to throw all the holes off. Put one bolt in loose and then start all the other ones, as stated above. The you'll want to tighten the middle ones first and work your way out. Do the cross over bolts last.
    It's possible that you got a bad one send them an email and they should exchange it for you. But first take to stock gasket and see if all the holes line up, if they don't take a pic and send it with the email to them and post it here.
    No more GP 04 Impala SS Indy:
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by Nixon View Post
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  16. #16 Re: PLOG install not going well
    Out West
    Quote Originally Posted by dazedandconfused View Post
    It's true.
  17. #17 Re: PLOG install not going well
    I've seen this before. They likely welded the flange on backwards. Hold your gasket up to the plog and then to the motor. You'll find it's likely backwards.
    Now you can swear about ZZP over the bolt you need to remove from the head and we'll all understand.
  18. #18 Re: PLOG install not going well
    May 2008
    Winnipeg, MB
    LOL, that could very well be the problem.
  19. #19 Re: PLOG install not going well
    It's a ZZP product, I'm not saying anything about their quality control....but they have a consistency on some things. Quality...isn't one of them.
  1. WTB rear turbo plog, front plog and Z7 Crossover
    By Wotgtp in forum Wanted To Buy - Parts
    Last Post: 02-20-2012, 07:39 AM
  2. How hard is it to install a plog and 3.4 pulley
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 02-07-2011, 06:40 AM
  3. Do I need a gasket for a PLOG install?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 01:11 AM
