Thread: Problem starting my 2000 Grand Prix
Results 1 to 7 of 7
  1. #1 Problem starting my 2000 Grand Prix
    Plymouth WI
    I have a problem starting 2000 Grand Prix with the 3.8L (K) Engines. Drove it in the garage and the next day it would not start. It turns periodically while trying to start one or so cylinders will fire but will not start. There are no codes, code reader states good to go. While working on the car I added new wires and plugs. The fuel gage was at an 1/8 of a tank, the fuel pump did not run until I replaced the vapor canister purge valve. Now have fuel pressure up to the injectors. Also added 6 gallons of gas just in case the fuel lever is incorrect. Spark check looks good. Kept the car with heater overnight just incase the fuel line was froze. Any help would be greatly appreciated.
  2. #2 Re: Problem starting my 2000 Grand Prix
    St. Louis
    Have you checked all the fuses? Might have popped one. If you say you have spark and fuel, then it "should" run. Also, check to make sure all your electrical connections are tight. Especially since you just did work on it and now it won't run. Check around the areas that you did work and see if you knocked anything loose.
  3. #3 Re: Problem starting my 2000 Grand Prix
    What do you mean by "it turns periodically"? It should turn over easily. If it's turning super slow and sometimes won't, then you need to charge the battery.
  4. #4 Re: Problem starting my 2000 Grand Prix
    Plymouth WI
    Thanks for the replys. The battery is fully charged, the engine turns over very easily. I changed the wires only after the engine did not run, and I replaced the wires one wire at a time. No loose connections. When I try starting the car, at first it turns a couple revs and then I can here one or two cylinders fire, but does not start. After that it just turns with no additional cylinders firing. I checked the fuel pressure by the injectors, when I turn on the key I can hear the fuel pump run, the pressure reading got up to 50psi, however my pressure tester does not have a good seal at the test point. After a few seconds with the key on the fuel pump turns off and the pressure drops to zero. I checked all the fuel line fuses. IF I am getting a spark on one of the cylinders I didn't think to look at any other fuses. My thought is I may need to replace either the crank shaft sensor & or the cam sensor, however I am supprized no codes are being registered.
  5. #5 Re: Problem starting my 2000 Grand Prix
    Nov 2009
    Grand haven
  6. #6 Re: Problem starting my 2000 Grand Prix
    SE Level Member awesomefullness's Avatar
    Red Deer Canada
    since you suggested that you placed a heater to keep everything from freezing up, i suspect you're in a colder environment.
    Sounds alot to me like water in the fuel lines, which is especially common if you're a winter driver that's in and out of a heated garage, or if you keep a tank below 1/4 in the winter. Condensation will occur very easily if you do either of these, so try some gas line antifreeze with water remover in it. You can find it at almost any parts store that stocks winter items.
    If you continue to pull in and out of a heated garage after, it would be ideal to use gas line antifreeze with every tank.
    Give that a try, hope it helps!
  7. #7 Re: Problem starting my 2000 Grand Prix
    Jul 2011
    slidell,la
    Quote Originally Posted by HNorm View Post
    just changed my crank shaft sensor runs great now ,try it i just changed all kind of stuff and it was that all along !
  1. 2000 Grand Prix GT- not starting
    By grneyes908 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:25 AM
  2. Please help, 2000 Grand Prix starting/stalling problems
    By mjs173 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:22 AM
  3. 2000 Grand prix Tranny problem
    By Slickgrandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-04-2011, 04:45 PM
  4. 2000 grand prix gt Interior lamps problem
    By rainlake in forum General Tech Discussion
    Last Post: 06-01-2010, 04:34 PM
  5. 2000 grand prix traction control problem
    By marckub203 in forum Introductions/Noob Questions
    Last Post: 08-19-2009, 10:02 PM
