Thread: Outside temp gauge on climate control
Results 1 to 10 of 10
  1. #1 Outside temp gauge on climate control
    Jersey
    Since i bought my car in June I noticed the outside temp on the climate control was never reading correctly. It would say 34* when it was really 97*
    does anyone know how to fix this?
    16' wrx sti- stock
  2. #2 Re: Outside temp gauge on climate control
    Banned
    Wichita Falls, Texas
    Probably just a bad sensor. Consider replacing it.
    Only place you would probably be able to get one however is the junkyard or the dealer. Do you have a junkyard locally?
  3. #3 Re: Outside temp gauge on climate control
    SE Level Member GTP00Matt's Avatar
    May 2008
    Delavan, MN
    Mine was like this when I bought it too. It was the sensor. It's really not very expensive at all from the dealer and is pretty easy to change. It's up in front of the radiator took me 5 min to change. My A/C wouldn't work on auto because of it being bad.
    2000 GTP coupe, totally stock
    1995 Chevy K2500 6.5 TD 4" straight pipe 285 BFG's on 16x8 American Racing Nitro's
  4. #4 Re: Outside temp gauge on climate control
    Jersey
    ohh I think i know where it is, i was looking at it when i put on my DP, im like what the hell is this . But yeah there is a junkyard about 15 miles from my house. Maybe il check there since the dealer had been ripping me off lately
    16' wrx sti- stock
  5. #5 Re: Outside temp gauge on climate control
    Apr 2008
    Wheaton, il
    Got mine at AutoZone. $18.00 and fixed the problem.
  6. #6 Re: Outside temp gauge on climate control
    Moore,OK
    Quote Originally Posted by macs2000gtp View Post
    you got a p/n for it?
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  7. #7 Re: Outside temp gauge on climate control
    Moore,OK
    Quote Originally Posted by whiteknuckle View Post
    nevermind i found it
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  8. #8 Re: Outside temp gauge on climate control
    Jersey
    i finally got mine $14.97 at autozone
    16' wrx sti- stock
  9. #9 Re: Outside temp gauge on climate control
    SE Level Member dlindeken's Avatar
    St. Paul, MN
    Did this fix it? I have seen other posts on here stating that its just a matter of changing the wiring too to change to farenheit from celsius.
  10. #10 Re: Outside temp gauge on climate control
    Jersey
    Yeah, it was just the little sensor. Problem solved
    16' wrx sti- stock
  1. Digital CLimate control
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 10-15-2009, 08:01 AM
  2. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  3. Dual zone climate control
    By CT Tech in forum General Tech Discussion
    Last Post: 07-10-2008, 02:05 PM
