Thread: Connect to scanner?
Results 1 to 2 of 2
  1. #1 Connect to scanner?
    May 2012
    Michigan
    Hi guys, I have a problem and I am stumped on it. I have a 1999 grand prix gt and when i connect an obdII scanner on it, it won't connect and I can not figure out why. It powers the scanner to turn on but then says connection error. I have tried many different scanners and all of them say error. I was told that they are on the same fuse as your lighter and that works. Any help would be greatly appreciated.
  2. #2 Re: Connect to scanner?
    St. Louis
    Double check the owners manual and see if there is a separate fuse for the OBD port.
  1. Scanner Doesn't Connect To ECM
    By grandamle91 in forum PCM Tuning
    Last Post: 06-25-2011, 10:39 AM
  2. Wire with nothing to connect too....
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2010, 11:32 PM
  3. Facebook Connect?
    By JDCMoney in forum Off Topic Discussion
    Last Post: 10-28-2009, 10:26 AM
  4. **FIXED**Can't get tuner to connect
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 03:51 PM
  5. connect throttle cable to pre 99 N* TB
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-30-2008, 10:52 AM
