Thread: Warm Air Intake
Results 1 to 20 of 35
  1. #1 Warm Air Intake
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    my warm air intake has a 3 inch metal pipe and a generic filter on it.
    my only problem is that it whistles around 3k rpm.
    I HATE THE WHISTLING
    my friend has a 4 cylinder with a WAI and it roars.
    How can i make mine roar? do i need a wider pipe or a better filter?
    Any ideas guys?
  2. #2 Re: Warm Air Intake
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    is your car a gtp?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    nope. 98 GT.
    Series 3 engine though
  4. #4 Re: Warm Air Intake
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Quote Originally Posted by Kolton Lock View Post
    nope. 98 GT.
    So we can fit the 3800 Series 3 engine in our cars? What did it come out of?
  5. #5 Re: Warm Air Intake
    Oct 2011
    Michigan
    well im not sure what whistling your hearing but my open cone makes the same noise id just imagine thats how 3800s sounds
  6. #6 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    it sounds just like a high pitched suction. i'm just upset that a 4 cyl. sounds SO MUCH BETTER
  7. #7 Re: Warm Air Intake
    Oct 2011
    Michigan
    that vacuum sounds sweet very mean sounding
  8. #8 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    not on mine lol
    its sad. i should share a video haha
  9. #9 Re: Warm Air Intake
    Pennsylvania
    On my series 3, the only whistling I hear is at start up and it lasts about 30 seconds... I believe it has to do with the idle air control valve.
    It starts up and it has this ear piercing whistle to it, then it runs with the whistle for about 30 seconds and it sounds like a vacuum cleaner opens up followed by a click and then a sound like a vacuum cleaner turned off, and the whistle goes away. From there it sounds like a car with a normal intake running, until I get on it and then it roars like a beast, intake was the best thing I ever did for the sound of my car, lol.
    And then when I step on the gas hard you can hear it take a deep breath before the motor revs... WHOOOSH VROOOOOOOOM
    Sport Edition Kv5 18x8
  10. #10 Re: Warm Air Intake
    Oct 2011
    Michigan
    yes please do
  11. #11 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    could my little rubber mount for the o2 sensor be making it whistle? lol
    mine is silent at start up and idle.... then 3k its whistly
  12. #12 Re: Warm Air Intake
    Pennsylvania
    Rubber mount for the o2 sensor? The o2 sensors are in the exhaust pipe, not in the intake.
    That's mine
  13. #13 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    whoops sorry the MAF sensor. sorry i'm exhausted lol
    yeah the rubber grommet doesnt EXACTLY fit.. so its kinda shoved in hah
  14. #14 Re: Warm Air Intake
    Pennsylvania
    yeah, that could be whistling I guess if it's not sealed.. which if the leak is after the maf it's probably affecting your performance because the maf isnt recording that air for the pcm.
  15. #15 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    i will look harder tomorrow
    and maaybe get a video if i can find my camera haha
    Quote Originally Posted by FriboRage View Post
    Do you even have an iac valve? Wouldnt the pcm just open the throttle blade?
    A whistling noise is indicitive of a small leak in the intake.
    There is typically a shovel over gravel noise when using an l36 or l67 tb.
  17. #17 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    everything besides the intake manifold came out of a 2007 Grand Prix GT
  18. #18 Re: Warm Air Intake
    Nov 2010
    So if I found a series 3 engine and use a supercharger and intake manifold from a series 2 engine, that would work?
  19. #19 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    Points, In theory it should work. i'm not entirely sure of this. as i'm new to the grand prix scene, but i have found about 99% of the parts are interchangeable through Series 2 and 3
  20. #20 Re: Warm Air Intake
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    gone threw many intake setups, as well as changed my pcv valve, under qtr\half throttle yes it will whistle, any less/more then half throttle whistling goes away.
    get used too it.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  1. Issue when car is warm
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2011, 05:40 PM
  2. Warm stalling
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-03-2011, 04:49 AM
  3. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
  4. Any way to quiet down an intake during the "warm up" stage?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 01:37 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
