Thread: Warm stalling
Results 1 to 7 of 7
  1. #1 Warm stalling
    Jun 2010
    Hampton, VA
    Looking for assistance... 01 GT runs fine when cold, stalls when warm. Holding the RPM's up, it runs rough, missing and sputtering. Returning to idle, may as well turn off the key. No codes. Trying to start when warm it fires and dies. checked fuel pressure and it's right, 55 PSI cranking, 50 PSI KOEO and 45 PSI running (cold). This really acts like a fuel pump but with the pressures being what they are?? I'm open to all opinions. Thanks in advance
  2. #2 Re: Warm stalling
    St. Louis
    When it gets warm and dies on you, try unplugging the MAF and see if it starts/runs.
  3. #3 Re: Warm stalling
    Dec 2008
    Lawndale, CA
    I have had issues with the fuel pressure regulator on an L36 which caused starting issues when starting the car after it was warm. Are you getting any kind of code?
  4. #4 Re: Warm stalling
    Jun 2010
    Hampton, VA
    I'll try the MAF sensor. I think I have pretty much ruled out fuel pressure and fuel pump as possible causes.
  5. #5 Re: Warm stalling
    Jun 2010
    Hampton, VA
    replaced the MAF, wife drove it around today. after about two hours of various errands, it failed again to the point that she had to call AAA. would not stay running. I got home, it started, ran fine for 45 min. drove it around the neighborhood, shut it off, re-started, Repeated. Everything seems normal. Anybody got a clue?
  6. #6 Re: Warm stalling
    St. Louis
    Beginning to suspect the ignition. When it won't start pull a plug wire off and ground it to something and attempt to start it. Look to see if you are getting spark. Might be the ICM going.
    My only other thought is the Crank Position Sensor. Right before it dies does the tach ever drop to zero?
  7. #7 Re: Warm stalling
    Jun 2010
    Hampton, VA
    Not the cps. Experienced that before. Don't think it's the ICM. I'll check spark anyway when it happens again.
  1. 99' Grand Prix 3.8L stalling out when it gets warm
    By Michelleb76 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 04:28 PM
  2. Starts then dies warm
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2010, 07:02 PM
  3. diffucult warm start
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 07-03-2010, 07:31 PM
  4. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  5. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
