Thread: bubbling noise
Results 1 to 14 of 14
  1. #1 bubbling noise
    Northeast Ohio
    so the last new weeks i have been noticing a bubbling noise almost like in my glove box(heat core area) when i first start up the car and get moving in the morning never did it prior so it could be nothing and my friend says when i get on it im shootin a bit of black smoke so im thinking my intake mani might be loose....anyone have any other ideas? excuse me if im sounded a bit dumb haha
  2. #2 Re: bubbling noise
    Black smoke is just raw unburnt fuel when you hit tip in and it dumps fuel for the crap ton of air that is coming in.
    How is the coolant level???
    That sound alot of times is coming from the heater core.
  3. #3 Re: bubbling noise
    London Ont, Canada
    bleed your coolant with the car on an angle, engine up
    keep doing that for a few days , it will be gone
  4. #4 Re: bubbling noise
    Northeast Ohio
    it just started doing it recently never had the issue before and the level is fine and its not like im force induction or even have a cai that y i think my uim my be loose and sucking in air from what i read that will cause the bubbling as well
  5. #5 Re: bubbling noise
    London Ont, Canada
    mine did it when i first bough it, got it fixed up with my method.. then yesterday when i had the TB off air got in, i forgot to bleed it before going for a spin, so now I've got a little gurgle back.
  6. #6 Re: bubbling noise
    Northeast Ohio
    do you thinking doin the old school burp method will work?
  7. #7 Re: bubbling noise
    sounds like air in the cooling system, bleed it. and when was your last tune up?
  8. #8 Re: bubbling noise
    Northeast Ohio
    i did plugs and wires at 80k couldnt pass the deal up and went with acdelco parts
  9. #9 Re: bubbling noise
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    bleed it and pressure test.... just to see if its gon to start seeping pressure to allow air in.... trust me ive just finished going thru this..
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  10. #10 Re: bubbling noise
    London Ont, Canada
    take your air intake off, check out your TB.. is it all black and caked? or clean? move the flap to see
  11. #11 Re: bubbling noise
    Quote Originally Posted by 06PONTGP View Post
    80,000 don't help tell how long ago lol 10 or 20,000 ago would tho.....so what is your current mileage?
  12. #12 Re: bubbling noise
    Northeast Ohio
    sorry 30k ago
  13. #13 Re: bubbling noise
    with iridium plugs? they last a lot longer, like 70,000 miles, but if you went with copper core plugs they only last 10 to 15,000.
  14. #14 Re: bubbling noise
    Northeast Ohio
    ac delco iridium
  1. Tie rod noise
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 12-16-2011, 03:46 PM
  2. AC noise??
    By grandprix85 in forum General Tech Discussion
    Last Post: 07-20-2011, 08:07 AM
  3. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  4. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  5. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
