Thread: Help!!! injector leaking from top near fuel rail...how do you fix it?
Results 1 to 14 of 14
  1. #1 Re: Help!!! injector leaking from top near fuel rail...how do you fix it?
    Apr 2009
    Fort Worth TX
    What should also be mentioned is that when the top o-rings are old they dry rot and get hard. This is probably why they are leaking. The rail cup is conical shaped and removing the injector can be difficult. I turn the rail upside down and spray the cup opening with PB blaster and it makes a world of difference when pulling the injector out.
  2. #2 Re: Help!!! injector leaking from top near fuel rail...how do you fix it?
    Mar 2012
    cincinnati
    Thanks to all who replied, I repaired them and back on the road, no leaks so far, I will be watching this troublesome area. Thanks GM for yet fun filled afternoon , the O ring in question was rolled upon install and pinched. On a lighter note I did clean all the injectors and I can tell an increase in performance.
  3. #3 Re: Help!!! injector leaking from top near fuel rail...how do you fix it?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by gmlover13 View Post
    Thanks to the last person that worked on my car for the fun filled afternoon ,
    This sounds more like it. Right Bill? LOL
