Thread: 2004 GT1 - Battery Cables
Results 1 to 3 of 3
  1. #1 2004 GT1 - Battery Cables
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Hi everyone. Long time Grand Prix owner, First time poster on this forum.
    I have a 2004 Grand Prix GT1. I've had it for 7 years (Original owner) and it currently has 170,000 miles on it. Hands down, best car I have ever owned. Enough of the praise of the Grand Prix and time for the question.
    My battery died this morning and I had to get it replaced. (2nd Battery I've had to put in it. The 1st one lasted about 3.5 years and about 100K.) Luckily for me it was still under the free replacement program from Autozone so it was swapped out at zero dollars. As I was replacing the battery, I was fighting with the negative battery cable. As I'm sure everyone knows, it's a tight fit to get the cable on.
    As I was re-installing the cables, I couldn't help to wonder why Pontiac just didn't make the cables side mounted versus the top mounted or give some extra slack on the cables to make installing an aftermarket battery and still have it sit in the tray correctly.
    So the question is. Is there a retrofit cable to switch them over to side posters or a way to get some extra slack into them?
  2. #2 Re: 2004 GT1 - Battery Cables
    Kansas
    You could make yourself new ones and run it with additional length. You could try some of these as well, screw into side terminals and still use same battery connections.
    Amazon.com: Pico 0893PT Side Mount Battery to Post Adapter 1 Set per Package: Automotive
    Outside of making your own, no not really.
  3. #3 Re: 2004 GT1 - Battery Cables
    Apr 2012
    Wilbraham MA
    Quote Originally Posted by NegativeOne13 View Post
    Great Solution - Thanks for posting
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  1. Replacing main battery cables
    By Impala131 in forum Audio, Security & Visual Electronics
    Last Post: 04-26-2012, 05:04 AM
  2. Battery 2004 Grand Prix GT
    By theclarks1 in forum General Tech Discussion
    Last Post: 02-11-2012, 02:03 PM
  3. Best place to get battery cables
    By GTP in RTP in forum General Tech Discussion
    Last Post: 12-19-2011, 05:59 PM
  4. Shifter Cables
    By jaydasparkz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2011, 08:51 PM
