Thread: Looking for any E85 info
Results 1 to 7 of 7
  1. #1 Looking for any E85 info
    Apr 2012
    wi
    I did a couple searches on but really couldn't find much info on running E85. Is there any info on anybody running and what they had to do to run it around? Post links if you have some please....
    Thanks for your time
  2. #2 Re: Looking for any E85 info
    Bigger injectors, new fuel filter, a few other things and a custom tune.
  3. #3 Re: Looking for any E85 info
    Apr 2012
    wi
    Just curious because 93 octane is getting harder and harder to find around here so trying to figure out if its worth it to to do the conversion. Plus is going to help when I start really modding the gtp?
  4. #4 Re: Looking for any E85 info
    I will help a lot from what i understand its around 110 octane or so i think.
  5. #5 Re: Looking for any E85 info
    You only have to run 91+, so 91 and 92 are still what you can run.
    Its about 104 octane if I remember right.
  6. #6 Re: Looking for any E85 info
    Also e85 will net you alot less miles per gallon aswell. Hence bigger injectors, custom tune yadda yadda.
    So if you care about fuel mileage at all, this is not what you want.
  7. #7 Re: Looking for any E85 info
    Feb 2009
    flintnasty MI
    A custom tune is not required... It is probably recommended for maximum gains though.. You can bolt a 3.2 pulley and 42# injectors to a completely stock car, toss a fresh tank of e85 in and run mid 13s.
    Other than that... the "required" list is totally relevant to your goals. I make more power on E85 than I did on 110 race gas... and I am a bit faster at the track it seems with E85 over $17 a gallon C16 race gas.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Need some info if possible
    By coffcc3408 in forum Off Topic Discussion
    Last Post: 03-08-2012, 11:15 PM
  3. New here & need info...
    By MurphysLaw in forum Visual/Body Modifications
    Last Post: 01-28-2010, 01:31 PM
  4. Does anyone know more info about the HV3?
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 01-12-2010, 01:48 PM
  5. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
