Thread: Old Thread
Results 1 to 10 of 10
  1. #1 Old Thread
    USA
    Old Thread
  2. #2 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    The same thing happened on my 2005 GP , the spring broke(very common on this model) . I took it to carmax where I bought it and since it was still under warranty they fixed it by replacing the whole hud unit. DO you still have warranty ? If you do they should honor the repair. Also if you decide to do it yourself be careful uninstalling the dash unit around the HUD it is sensitive as an eggshell.Good Luck
  3. #3 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Jan 2009
  4. #4 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Jan 2009
    Man well that does kind of suck, but if it makes you feel any better carmax damaged my dash unit and I didnt realize like 2 months after. Good thing I found the unit for $40 online . This is a link that will help if you decide to fix the hud HUD - Heads Up Display for Pontiac Grand Prix 2004 Repair Instructions . Try going to the dealership to see how much it will cost to repair.
  5. #5 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Jan 2009
    Yeah I just realized that you posted the same link
  6. #6 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Only one delicate thing stands between you and fixing this, that's the hud trim panel. Because it sits in the sun and it's not the most durable thing to begin with...that's your only hurdle.
    A local guy brought his by and told me, "I know that panel is likely breaking, go on and fix it." Yes there was a crack in the hud panel before I started and a second one upon completion, this overall is a super easy fix.
    I removed the hud, which has no wiring tricks, it's a simple plug. No craziness....simple and easy to unplug it's connector. Then unscrew or lift it out, remove screws to get into it. From there I drilled a new hole in the thicker part of the plastic, reconnected the spring and tested it out.
    If you can get past the trim panel and operate a screwdriver/drill. This will be easy.
  7. #7 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    If you don't think you can handle it.. Either cruise to CT or pm Buickman104. He's in NYC
  8. #8 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Jan 2012
    Philadelphia
    HUD display's temp? Mine only shows me gas light, speed, turn signals, high beams, and i think the check gauges lights and stuff like that it might tell me if my temp light comes on but i dont know.
  9. #9 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    Eddie...he's has the newer version.
  10. #10 Re: After Having My Car For Only 2 Weeks, My HUD Broke
    GTP Level Member buickman104's Avatar
    NYC
    Let me know if anything.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Best 2 weeks notice ever!
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 08-17-2011, 01:30 PM
  2. 7 weeks later
    By fri3dchick3n in forum Off Topic Discussion
    Last Post: 08-09-2011, 01:36 AM
  3. Quart of oil in 3 weeks
    By rechristel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2011, 09:08 PM
  4. Where was this 2 weeks ago
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-01-2009, 04:15 PM
  5. Getting 2001 GTP in 3 weeks
    By jacobmh27 in forum Introductions/Noob Questions
    Last Post: 03-25-2008, 10:21 AM
