Thread: fuel gauge acting up and im stumped
Results 1 to 8 of 8
  1. #1 fuel gauge acting up and im stumped
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    so i have the car on a life it reads a quarter of a tank which is how much is in there, so i drive it on the lift a bit take it out of the garage and park it then i drive it 4 miles and all of a sudden the needle drops and the low fuel light comes on then 2min later it goes off then i get the "low" warning on the DIC then the low fuel light comes back on i park it in my flat garage turn it off let it sit for a while then drive it again to do things then its fine back to a quarter tank and everthings fine wft is going on the sending unit/fuel pump is 7 months old
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: fuel gauge acting up and im stumped
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    you sir have a gas guzzler
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: fuel gauge acting up and im stumped
    Oct 2011
    Michigan
    no no it went back to normal maybe 45min later it just acted up for a bit
  4. #4 Re: fuel gauge acting up and im stumped
    brunswick
    maybe its because the gas moved cause the car moved
  5. #5 Re: fuel gauge acting up and im stumped
    fuel sender
  6. #6 Re: fuel gauge acting up and im stumped
    Sep 2011
    MI
    Sender... I think GM has some stuff that you put in the tank that is suposed to clean the contacts.... Not sure if it works.
    but at 7 months, it should be under warranty.
  7. #7 Re: fuel gauge acting up and im stumped
    Techron
  8. #8 Re: fuel gauge acting up and im stumped
    Apr 2009
    Fort Worth TX
    It's easy to remove the FP from the tank and check the sender. Resistance should increase as the slider moves upward on the variable resistor. Hook up a DVM to the leads and move the float up and down. The change in resistance should be very linear without any dead spots (open).
    If there are dead spots try and bend the slider so it makes better contact with the variable resistor.
    When I installed my pump the sender was very erratic at first. A month later it was working fine...guess the slider had to wear in.
  1. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  2. Fuel Gauge
    By racecardude310 in forum General Tech Discussion
    Last Post: 01-22-2010, 04:56 AM
  3. P0140 code and boost gauge acting weird
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-14-2009, 07:50 AM
  4. Fuel Gauge acting up
    By 97HoHum in forum General Tech Discussion
    Last Post: 04-30-2009, 11:16 PM
