Thread: Check Engine Lights
Results 1 to 8 of 8
Threaded View
BlackGT1 Check Engine Lights 04-12-2012, 08:30 PM
BlackGT1 Re: P0420 and P0440 Error... 04-13-2012, 12:00 PM
BlackGT1 Re: Check Engine Lights 04-15-2012, 11:54 AM
The Guz Re: Check Engine Lights 04-15-2012, 02:11 PM
BlackGT1 Re: Check Engine Lights 04-15-2012, 04:34 PM
dsmuts Re: Check Engine Lights 04-15-2012, 04:36 PM
SoergBot Re: Check Engine Lights 04-15-2012, 04:43 PM
BlackGT1 Re: Check Engine Lights 04-15-2012, 08:40 PM
  1. #1 Check Engine Lights
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    I have had the P420 code pop up three times since I owned the car. Once about 5 months ago, for reasons unknown, the other two about 3 months, and two months ago, both after hitting a hard pot hole or bump I didnt notice.. Arlington has ****ty roads. The last time, about 2 weeks ago, was while the car was idling warm foor about 5 minutes it tripped.... not sure if it truly is the cat, or something else... wouldnt it come on more often if it was the cat? should I check my o2 sensors or no? just really hoping its not the cat.
    The P0440 came up twice... both under a semi hard braking manuever, I know its commonly a gas cap, but what other things can it likely be on this car?
    Any feed back is welcomed.
    Added: Also wondering if its a o2 sensor because the best I've every got out of a tank of gas is 340miles with a light foot. And thats bone dry 17.2 gallon fill up. Ive heard bad o2's cause bad MPGs.
    2001 GT - Mods, Magnaflow Mufflers, K&N CAI
  1. P0440
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 03-03-2012, 07:13 PM
  2. dtc code p0440
    By churchryan55 in forum Introductions/Noob Questions
    Last Post: 01-23-2011, 12:23 PM
  3. p0440
    By eroth in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 11:05 AM
  4. p0440
    By eroth in forum General Tech Discussion
    Last Post: 03-23-2009, 07:45 PM
  5. P0440 code
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:32 PM
