Thread: Check Engine Lights
Results 1 to 8 of 8
  1. #1 Check Engine Lights
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    I have had the P420 code pop up three times since I owned the car. Once about 5 months ago, for reasons unknown, the other two about 3 months, and two months ago, both after hitting a hard pot hole or bump I didnt notice.. Arlington has ****ty roads. The last time, about 2 weeks ago, was while the car was idling warm foor about 5 minutes it tripped.... not sure if it truly is the cat, or something else... wouldnt it come on more often if it was the cat? should I check my o2 sensors or no? just really hoping its not the cat.
    The P0440 came up twice... both under a semi hard braking manuever, I know its commonly a gas cap, but what other things can it likely be on this car?
    Any feed back is welcomed.
    Added: Also wondering if its a o2 sensor because the best I've every got out of a tank of gas is 340miles with a light foot. And thats bone dry 17.2 gallon fill up. Ive heard bad o2's cause bad MPGs.
    2001 GT - Mods, Magnaflow Mufflers, K&N CAI
  2. #2 Re: P0420 and P0440 Error Codes
    Sep 2011
    Fort Worth, Texas
    bump
  3. #3 Re: Check Engine Lights
    Sep 2011
    Fort Worth, Texas
    Had a new code today... I had a P0442 today. Evaporative Emission System Leak Detected (small) Could this be the o2 sensor as well?
  4. #4 Re: Check Engine Lights
    Dec 2008
    Lawndale, CA
  5. #5 Re: Check Engine Lights
    Sep 2011
    Fort Worth, Texas
    I should have read up more on the 0442 code, was in a hurry to leave for somewhere so I didnt research it. Guess I'll be getting a gas cap.
    Also is a Bosch o2 sensor just as good as AcDelco.. normally I'd go with a stock part on this type thing.. but on Rockauto, the Bosch one is cheaper.
  6. #6 Re: Check Engine Lights
    I've heard bad things about bosch
  7. #7 Re: Check Engine Lights
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    could be evap canister if not gas cap
  8. #8 Re: Check Engine Lights
    Sep 2011
    Fort Worth, Texas
    Quote Originally Posted by SoergBot View Post
    Where is the location of the Evap Canister?
    See, I've heard bad things about Bosch plugs and wires, but great things about them in other vehicles.. so i wasn't sure about the o2 sensers
  1. P0440
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 03-03-2012, 07:13 PM
  2. dtc code p0440
    By churchryan55 in forum Introductions/Noob Questions
    Last Post: 01-23-2011, 12:23 PM
  3. p0440
    By eroth in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 11:05 AM
  4. p0440
    By eroth in forum General Tech Discussion
    Last Post: 03-23-2009, 07:45 PM
  5. P0440 code
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:32 PM
