Yeah you can pull out your upstream o2 and drive around and see if it gets better and if it does then your cat is probably clogged. What symptoms are you having?
Won't unplugging the upstream O2 sensor cause the car to run like crap either way, just due to how the computer uses the data?
2003 Grand Prix GTP.... the journey begins again....
E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
