Thread: Clogged cat, bad o2?
Results 1 to 7 of 7
  1. #1 Clogged cat, bad o2?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Alright so a few days ago I noticed when driving the SE that it would get surges where the RPMS would bounce a bit, in motion and at idle. Turn the car off and then back on and it would releave it for a few miles. I got an SES light and 2 things came up
    1. Multiple cylinder misfire
    2. o2 bank 2 low voltage
    When I got back to the house I erased the codes after checking wire connections and spark. Took it back out where the problem persisted. This time only getting one code
    1. Cylinder 4 misfire.
    This time I took the plug out and put in another that I had as a spare just to see if that really was the issue. Well sure enough the problem continues with the same code(s) coming up each time. I haven't seen the o2 code since that one time though, but is it a possibility that it is what's causing the issue? I mean with the tune it does run rich and would make sense if it went bad. Or maybe the cat? Has almost 300k miles on it and with it running rich since the swap maybe have done it in. I have spares of both things but don't want to bother if no one thinks that's the issue. Let me know what you guys think and i'll def look into it
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  2. #2 Re: Clogged cat, bad o2?
    a clogged cat would make the car feel like it has no power. if you got into the throttle it would feel like its bogging down.
  3. #3 Re: Clogged cat, bad o2?
    Wooster, Ohio
    if it can't exhale theres no where for the clean fuel and air to go though, sounds totally possible to me with 300k, mine was shot at 220k Theres only a few other things that can cause a random misfire and with a O2 issue on top of that, thats where i would start
  4. #4 Re: Clogged cat, bad o2?
    Nov 2008
    Well a little more info on the problem, when you give it gas it studders, like little blurps of power... Best way I can describe it would be speed bumps
  5. #5 Re: Clogged cat, bad o2?
    Quote Originally Posted by ninnyGTP View Post
    Sounds a lot like a misfire. If cylinder 4 is the only one lighting up the screen, diagnose the cylinder only and not something that should cause misfires at all cylinders.
    Plug
    Wire
    Wire not touching the O2 wiring
    Coil pack tower clean?
    Coil firing that cylinder?
    Injector firing? Read the plug.
  6. #6 Re: Clogged cat, bad o2?
    Wooster, Ohio
    def sounds like cat, thats what mine did, almost feels like a REALLY out of place rev limiter, basically you have to hold it wide open and after awhile it MAY climb a little higher but probably not, if thats basically it i would start there!
  7. #7 Re: Clogged cat, bad o2?
    Nov 2008
    I'll check all connections and clean everything just to make sure. Get back to you with any updates
