Thread: Tuning question
Results 1 to 14 of 14
  1. #1 Tuning question
    Mar 2012
    Hillsboro mo
    Does anyone know if I have to get my car tuned right away after putting a 3.4 pulley on I have done the ubend and down pipe mods as well as the cold air thermostat and colder plug mods and am running e85 any input helps
  2. #2 Re: Tuning question
    did you upgrade injectors when you switched to e85?
    And if I'm reading this right you've only done a downpipe, intake, plugs and thermostat.
    So no plog?
    And a 3.4 pulley?
  3. #3 Re: Tuning question
    Mar 2012
    Hillsboro mo
    I haven't done put the pulley on yet but I went up two sizes in injectors have a 160 tsat and went to 3 inch down pipe bak and 3 heat range colder plugs no plog yet,k&n cai, and ordering a zzp custom PCM
  4. #4 Re: Tuning question
    So your running 60# injectors and e85 on the stock tune? Put a 180 thermostat in it or even a stock one. Your running al 103's?
  5. #5 Re: Tuning question
    Mar 2012
    Hillsboro mo
    I assume u mean auto lite 103s and no I'm running ngk I can't remember the number and its running great
  6. #6 Re: Tuning question
    160 is too cold, and 103 are too cold.
    So run a 180 and whatever 104's are in ngks
  7. #7 Re: Tuning question
    Mar 2012
    Hillsboro mo
    Ok and do I need a tune ASAP if I put the 3.4 on I have 0 k right now
  8. #8 Re: Tuning question
    Will all depend on how the car takes the pulley drop.
  9. #9 Re: Tuning question
    Mar 2012
    Hillsboro mo
    Ok do I won't know until I do the drop and scan for kr
  10. #10 Re: Tuning question
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Put the pulley on and scan. That will answer your question
  11. #11 Re: Tuning question
    Jan 1970
    Maquoketa, Iowa
    You kind of need to tune for ethanol, or buy a tuner, your car may be running right now because of the 30% or so larger injectors, but that isn't the right way of doing it. Once you get it tuned safely for ethanol and your injectors, then you can play with pulley sizes.
  12. #12 Re: Tuning question
    If you get a real tune for the E85 you could probably run the 3.4 pulley but i'd throw headers on if i were you too. Then you could go smaller still most likely.
  13. #13 Re: Tuning question
    Feb 2009
    flintnasty MI
    double post
  14. #14 Re: Tuning question
    Feb 2009
    flintnasty MI
    While I am completely lost and confused by this thread... Here are some facts.
    If you put e85 and 42# injectors in a stock gtp, you can basically run a 3.2 pulley without tuning and probably without exhaust mods.... and it would work pretty darn well. The stock tune on these cars is extremely underrated.
  1. Tuning question
    By 05GTPcmpg in forum PCM Tuning
    Last Post: 06-09-2011, 08:57 PM
  2. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  3. Tuning question
    By xsvtank in forum General Tech Discussion
    Last Post: 07-29-2010, 08:14 AM
  4. Powertuner fuel tuning question......
    By Iron Indian in forum PCM Tuning
    Last Post: 08-23-2008, 09:29 PM
  5. Quick question about tuning
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-21-2008, 09:49 AM
